When I try to play a DVD the audio and video shudders no matter what DVD or program I use. I tested my Drive with Nero CD-DVD Speed, and it listed the speed as 0.90x.
I'm pretty sure I have had this problem before, but I can't remember what I did to fix it.
Laptop: Dell Vostro 1000
DVD Drive: PBDS DVD+-RW DS-8W1P VBD1B
OS: Windows XP Home SP3
Is just one dvd that shudders? Or all? Homeburned or commercial? Burned dvds can be problematic.
One other thing to check is if your drive is stuck in PIO mode instead of DMA. You would see high CPU usage and the drive would be generally slow. Try this:
To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer.
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 19:03 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 00:51 -
Slow skipping response on MPEG1 2-pass VBR
By sparkomega in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 23:19 -
Ativa 18x dvd writer is real slow and tried everything to speed it up!!
By rotwiler in forum DVD & Blu-ray WritersReplies: 6Last Post: 13th May 2007, 00:21
