I have been getting file sizes in the 2GB range when I lock them at 4480 during set up. My last encode's log file is below. Thanks for any help.
D:\>"D:\D Drive\Downloads\RipBot264v1.15.0\tools\bepipe\bepi pe.exe" --script "import(^D:\temp\RipBot264temp\job1\job1.avs^) " | "D:\D Drive\Downloads\RipBot264v1.15.0\Tools\enc_aacPlus \enc_aacPlus.exe" - "D:\temp\RipBot264temp\audio.aac" --lc --br 262144 --mpeg4aac
BePipe by dimzon
Script used:
# BEGIN
import("D:\temp\RipBot264temp\job1\job1.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=6, BitsPerSample=16, SampleRate=48000Hz
Writing Header...
Writing Data...
0%
Done!
* AACPlus v2 Encoder (using Winamp enc_aacplus.dll and nscrt.dll)
* Coding Technologies encoder 8.0.3
* Build Oct 10 2009, 16:03:17
Input file: -
Output file: D:\temp\RipBot264temp\audio.aac
SampleRate: 48000
ChannelCount: 6
BitsPerSample: 16
Bitrate: 262144
ChannelMode: Multichannel
Engine: LC-AAC
Tune For Speech: No
PNS: No
MP4 Output: No
Encoding...
Finalizing...
Done
D:\>"D:\D Drive\Downloads\RipBot264v1.15.0\tools\avs2yuv\pip ebuf.exe" "D:\D Drive\Downloads\RipBot264v1.15.0\tools\avs2yuv\avs 2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" -raw - : "D:\D Drive\Downloads\RipBot264v1.15.0\tools\x264\x264_x 64.exe" --pass 1 --bitrate 7626 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 114227 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264" - 1920x1040 : 2
x264 [info]: 1920x1040 @ 23.98 fps
x264 [info]: using SAR=1/1
x264 [warning]: VBV bitrate (25000) > level limit (20000)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64
x264 [info]: profile Main, level 4.0
D:\temp\RipBot264temp\job1\job1.avs: 1920x1040, 10000000/417083 fps, 114227 frames
x264 [info]: frame I:1583 Avg QP:12.05 size:200881
x264 [info]: frame P:55594 Avg QP:14.45 size: 58754
x264 [info]: frame B:57050 Avg QP:16.30 size: 16953
x264 [info]: consecutive B-frames: 24.7% 21.3% 5.7% 48.3%
x264 [info]: mb I I16..4: 33.0% 0.0% 67.0%
x264 [info]: mb P I16..4: 39.9% 0.0% 0.0% P16..4: 51.5% 0.0% 0.0% 0.0% 0.0% skip: 8.5%
x264 [info]: mb B I16..4: 5.3% 0.0% 0.0% B16..8: 28.2% 0.0% 0.0% direct:18.3% skip:48.2% L0:39.1% L1:44.7% BI:16.2%
x264 [info]: final ratefactor: 15.55
x264 [info]: direct mvs spatial:93.3% temporal:6.7%
x264 [info]: coded y,uvDC,uvAC intra: 40.9% 56.3% 36.7% inter: 22.9% 21.7% 3.0%
x264 [info]: i16 v,h,dc,p: 46% 21% 22% 11%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 22% 19% 7% 8% 6% 7% 6% 7%
x264 [info]: Weighted P-Frames: Y:4.5%
x264 [info]: kb/s:7642.90
encoded 114227 frames, 24.09 fps, 7642.90 kb/s
D:\>"D:\D Drive\Downloads\RipBot264v1.15.0\tools\avs2yuv\pip ebuf.exe" "D:\D Drive\Downloads\RipBot264v1.15.0\tools\avs2yuv\avs 2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" -raw - : "D:\D Drive\Downloads\RipBot264v1.15.0\tools\x264\x264_x 64.exe" --pass 2 --bitrate 7626 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 114227 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264" - 1920x1040 : 2
x264 [info]: profile High, level 4.0
x264 [warning]: specified frame type is not compatible with max B-frames
x264 [error]: slice=P but 2pass stats say B
x264 [info]: frame I:364 Avg QP:11.97 size:193610
x264 [info]: frame P:14359 Avg QP:14.48 size: 61175
x264 [info]: frame B:17589 Avg QP:16.40 size: 15813
x264 [info]: consecutive B-frames: 19.3% 20.2% 5.2% 55.3%
x264 [info]: mb I I16..4: 6.8% 79.4% 13.8%
x264 [info]: mb P I16..4: 2.8% 11.7% 1.5% P16..4: 42.5% 19.7% 14.4% 0.3% 0.5% skip: 6.5%
x264 [info]: mb B I16..4: 0.2% 0.8% 0.1% B16..8: 41.9% 1.3% 2.0% direct: 4.7% skip:49.1% L0:44.0% L1:46.1% BI: 9.8%
x264 [info]: 8x8 transform intra:73.6% inter:72.7%
x264 [info]: direct mvs spatial:89.0% temporal:11.0%
x264 [info]: coded y,uvDC,uvAC intra: 74.6% 80.0% 54.8% inter: 27.1% 31.3% 5.1%
x264 [info]: i16 v,h,dc,p: 28% 17% 11% 43%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 16% 36% 5% 6% 6% 6% 5% 6%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 19% 28% 5% 8% 6% 7% 4% 4%
x264 [info]: Weighted P-Frames: Y:7.1%
x264 [info]: ref P L0: 55.7% 19.9% 13.2% 10.4% 0.8%
x264 [info]: ref B L0: 76.8% 23.2%
x264 [info]: kb/s:7283.74
encoded 32312 frames, 6.86 fps, 7283.74 kb/s
D:\>"D:\D Drive\Downloads\RipBot264v1.15.0\tools\mp4box\mp4box.exe" -tmp "D:\temp\RipBot264temp" -add "D:\temp\RipBot264temp\video.264":name="9" -fps 23.976 -add "D:\temp\RipBot264temp\audio.aac":lang=eng -mpeg4 -chap "D:\temp\RipBot264temp\job1\chapters.txt" -new "C:\Documents and Settings\Administrator\Desktop\9.mp4"
AVC-H264 import - frame size 1920 x 1040 at 23.976 FPS
Import results: 32312 samples - Slices: 364 I 14359 P 17589 B - 32652 SEI - 340 IDR
AAC import - sample rate 48000 - MPEG-4 audio - 6 channels
Saving C:\Documents and Settings\Administrator\Desktop\9.mp4: 0.500 secs Interleaving
Elapsed Time: 02h:42m:59s
Results 1 to 1 of 1
RipBot 264 not creating an output file
By oxfordyankee in forum Blu-ray RippingReplies: 3Last Post: 30th Jun 2011, 12:32 -
Ripbot how to pick the right file?
By David9799 in forum Blu-ray RippingReplies: 4Last Post: 3rd Jan 2010, 16:59 -
buffer size 25000 in ripbot
By miss in forum Video ConversionReplies: 7Last Post: 4th Sep 2009, 10:07 -
Ripbot lock-size @ 8150 too big for DVD+R
By Z.Sath in forum Blu-ray RippingReplies: 14Last Post: 3rd Jun 2009, 07:44 -
Setting up default option for ripbot lock size and resolution
By Syco54645 in forum Authoring (Blu-ray)Replies: 0Last Post: 15th Dec 2008, 18:33
