I have several large HD avi video files on my hard drive and I want to remove a text logo in the bottom right corner of the screen. I downloaded virtualdub and the DeLogo filter with no problems. I followed the directions as best as I could but get stuck at the same place no matter what different things I try. When I try to load the .bmp file with red over the logo letters I get an error message that says the file is corrupted or not a .bmp file. I have triple checked the file and all is well. I even tried renaming the file but it did not work.
Do I need to rip(?) the HD 1920 X 1080 avi files to regular size avi first? Any help is needed.
THX
Mike
check out my videos:
http://www.youtube.com/user/DirtBikeMikeHubbard -
I've never tried using the DeLogo filter on a 1920x1080 source but it should work at that resolution. Are you sure your BMP file is exactly 1920x1080?
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 10:26 -
.MKV editing -- how to remove logo? (DeLogo equivalent)
By ralf07 in forum Video ConversionReplies: 2Last Post: 23rd Sep 2011, 06:44 -
Virtual Dub delogo output file help
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2011, 12:25 -
Merits of the delogo filter
By lordsmurf in forum RestorationReplies: 26Last Post: 10th Dec 2007, 06:09 -
Question from Barnabas about Delogo.
By Sean_ve99 in forum EditingReplies: 29Last Post: 2nd Aug 2007, 13:46
