right ive tried re-installing the drivers no look at all, im going to use divX but the aspect ratio is to small and i want to change it to 16:9 (youtube screen) but when i go to aspect ratio it is dulled out and wont let me click or select it. im using Power Director 8
Results 31 to 40 of 40
you are using composite to capture. it only does 4:3. any widescreen will be hardcoded with black bars top and bottom.
it may be that the drivers and that device don't work with win7 64 bit as i see you're using in your profile.--
hmm good point ill try and my dad's dell which runs XP, i can record in MPEG if i use Webcam instead xbox..... hmm im really confused..... is there another option rather then composite?
does it have s-video connection? small round plug? but that won't change the 720x576 size or give you widescreen, just a higher quality source.
i'm guessing hech54 is right and the game console doesn't output the tv signal in a way the kworld understands if you can record in mpeg-2 using a webcam but not the game. you could try in the settings to see if it has other tv formats listed that might work, maybe something like pal60.
you'd need a better capture device to get component or hdmi HD video.
http://www.blackmagic-design.com/products/intensity/--
On the other hand....if anything can get around the PAL60 problem it will be one of these little USB Doo-Dads. I've read of some of them have drop-down menu options for just such an occasion.Originally Posted by aedipuss
yeah im connected in pal 60......do you think i should give this a try on xp?
if you can get mpeg-2 to work in pal60 mode on win7 give it a shot.yeah im connected in pal 60......do you think i should give this a try on xp?
i know my pci kworld does. i wasn't sure about the usb version.aedipuss wrote:
_________________--
I too, think these things only record in mpeg2 ..(spent may hours puzzling this out) then convert to mpeg4.. got one of these to replace a broken DVD recorder.
Seems to be Hardware based mpeg2 .. now all I need is a svideo male to male lead, to work alongside my scart adapter.
Tried the Old Vic, but the male lead wasn't interested. Then you add the postage on top, cheap becomes mid pricedCorned beef is now made to a higher standard than at any time in history.
when i try to record my xbox i get sound but no image appereaing on power direcotr v8 why?
MPEG-4 is not meant to be a capture format unless it's using MPEG-4 hardware encoding. But even then...
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
No sound when capturing with KWorld DVD Maker PCI
By ibzomie in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 06:54 -
Kworld Expert dvd Maker - S-Video no picture
By johnstede in forum Capturing and VCRReplies: 3Last Post: 9th Aug 2009, 08:54 -
Problem with kworld dvd maker 2800D usb - Compression artefacts?
By jhowee in forum Capturing and VCRReplies: 5Last Post: 10th Feb 2008, 06:48 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
