Hello everyone! I'm new here in the forum and I've got a first question:
I use RipBot 1.15.0 and it doesn't keep my jobs queue. The temp folder on the HDD is still there. But no entry in the list. The checkbox keep jobs is chosen. If I want to test different settings, I have to demultiplex the video from start, each time. That's annoying... I deleted also the list, ripbot uses with the last encodings. But no matter. Each time it quits, the list is empty.
Can anybody help me or has an idea?
Thanks for your support,
Michael.
	hello Atak_Snajpera,
 thank you for the fast reply,
 I will try it.
  thanks. thanks.
	 works great! THANKS. works great! THANKS.
 but ripbot now sometime crashes during cq encoding. strange.
 I think a pass through tsmuxergui helps. Never remarked this
 with 2-pass encoding...
 I have to keep an eye on this...
	When RipBot crashes again, try posting the log file here and there may be something obvious in it. With H.264 encoding in RipBot, you also want to check CPU temperatures. The encoder runs all cores at about 100%, so the CPU will run hot and that might be the cause of a shutdown if there is nothing in the log that may show the cause.
 I do use tsMuxeR once in a while to sort out a odd BD before running through RipBot.
	"but ripbot now sometime crashes during cq encoding. strange. "
 You better check cpu stability in this tool
 http://dl.getdropbox.com/u/663563/LinX/en/LinX.7z
 select all available memory
 run it and wait couple hours
  Ripbot264 doesn't crop if resizing to 720p?By sparriskrigaren in forum Blu-ray RippingReplies: 3Last Post: 16th Jul 2012, 07:53
  Queue jobs in multiAVCHDBy SoberWarlock in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Dec 2011, 11:28
  XP-sp3 - seeking a fifo queue batch job schedulerBy hydra3333 in forum ComputerReplies: 0Last Post: 22nd Aug 2010, 07:30
  How to queue musicBy starkhund in forum ffmpegX general discussionReplies: 1Last Post: 3rd Apr 2010, 11:42
  DVDFlick, Queue Feature?By acid_burn in forum Video ConversionReplies: 1Last Post: 9th Sep 2007, 06:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
