Hi!!!
I have a AVI file (divx) with a 5 seconds keyframe n I wanto to cut/edit it!!!
The problem is... Everytime I set a starting point it saves the file statind at the previous keyframe.
I'm using direct stream mode, cause I just want to edit the file!!!
Does anyone knows what to do???
Or may be another software that would do the job???
Thanxs so much
I have not had this problem with AVIs but you could try using the delete frames option under VirtualDub. i.e.
1. select thew bit you don't want using the last two buttons (half left/right arrows)
2. select edit menu and choose 'delete selection'
3. save AVI (use direct stream copy)
Similarly you could try using the restrict range option under the video menu.
Thinking about it I assume you are using one of the two above menthods anyway BUT here are these just in-case.
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 18:16 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 22:47 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58
