Hey all. I captured all my home movies on Hi8 to AVI using VirtualDub. Can anyone recommend a good codec I can use to encode the video? I know there are tons but there must be some preferred ones out there.
Also which format is the most future proof? mpeg4? DivX,etc?
Thanks.
How do you plan on watching? (pc, dvd, blu-ray, media box , etc...)
That will limit your options
or do you mean a capture codec?
what do you mean by "best"? best speed to encode? best quality/size? best compatibility?... -
Not capturing codec but encoding.
I plan on watching videos from my home theater PC on my HiDef TV. -
Only goal would be quality of video and ability to play in the future. For example I dont want to use a codec that 5 years down the road nobody can play.
Encode to MPEG-2 at max bitrate for DVD-Video, for watching. About 4GB/hour.
Capture as HuffYUV lossless if you want to truly "archive" for possible later editing. Store on hard drives, video files will be 30-40GB/hour. Another option is MPEG-2 at 15mbps bitrate, which is maybe about half of HuffYUV, but still adequate to keep all video data intact.
Everything will be obsolete in 10 years, but DVD-Video and MPEG-2 will have the best legacy support. It's used for DVB, DVD and broadcasting, and will be for quite a bit longer. Divx is already obsolete, H.264 took its place. Took FLV's place, too.Want my help? Ask here! (not via PM!)
Get this one: TMPGEnc Plus 2.5
Guide for it at http://www.digitalfaq.com/guides/video/convert-tmpg.htm
An oldie, but goodie!Want my help? Ask here! (not via PM!)
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
Codec for VirtualDub
By TheGame111 in forum EditingReplies: 4Last Post: 21st Dec 2010, 20:05 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Hi8 encoding
By devin122 in forum Video ConversionReplies: 17Last Post: 17th Jan 2008, 11:41 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11
