i have recently tried to use my nero and when i go to add files to burn from my fvideo files i have been getting this message
"microsoft visual
c++runtime library
runtime error
program:\program files :\nero\nero 9\nero express\neroexpress.exe
this application has requested the runtime to terminate it in an unusal way
please contact the applications support team for more informantion " then
it says "NERO EXPRESS HAS STOPPED WORKING CORRECTLY"........
"A PROBLEM CAUSED THE PROGRAM TO STOP WORKING CORRECTLY. WINDOWS WILL CLOSE
THE PROGRAM AND NOTIFY YOU IF A SOLUTION IS AVAILIBLE
i have upgraded and uninstalled and re installed 7 times and have posted on their forum and am running out of options , please help me with this issues
[/b]
Closed Thread
Results 1 to 12 of 12
Does Win7 have mode option like Vista does where you can select to "Run in WinXP mode?" I read other posts where users got Nero to run in Vista by running it in WinXP mode.
Try this its only 6mb of install: https://www.videohelp.com/download/burnaware_free243.exeOriginally Posted by RBASH
you can easy uninstall if this not work for you.
Imgburn is better to use,most regulars here use it including myself.As to iso its just a container file that imgburn can burn and i hope you are downloading movies that are non copyright cause downloading copyright movies is against forum policy here.
Nero Version 9.4.26.0 and later is Compatible with Windows® 7 and will install without worry and run reliably with Windows® 7. According to Nero. Any Versions earlier than this will NOT run under Windows 7. To run under XP Mode you must have Windows 7 Professional or higher and your PC must be configered (Motherbord and CPU) to run XP Mode. Check with Microsoft for PC Compatabilty to run Windows 7 XP Mode. Hope that this helps.Originally Posted by RBASH
Why does Windows7 (but not Xp) have difficulty recognizing my mp3 player
By jimdagys in forum ComputerReplies: 4Last Post: 12th Apr 2012, 11:44 -
No erase this disc option in Windows7 Sometimes?
By Marco33 in forum DVD & Blu-ray WritersReplies: 4Last Post: 6th Jan 2012, 10:33 -
UBCD5 - Can Windows7 be wiped with it?
By ranchhand in forum ComputerReplies: 4Last Post: 11th Feb 2011, 15:11 -
Windows7 & True Image
By beam_brandon in forum ComputerReplies: 1Last Post: 23rd Sep 2009, 06:08 -
Problem with Avi-MuxGUI in Windows7 -Solved
By netmask56 in forum Video ConversionReplies: 0Last Post: 20th Jul 2009, 05:04
