I have an AVI where the frames appear to be suffled. In other words where the frames should go like this
1, 2, 3, 4, 5, 6, 7
they go like this
1, 3, 2, 5, 4, 7, 6
or possibly
2, 1, 4, 3, 6, 5, 8, 7
In other words each pair of frames is switched with the other in its position in the stream.
The effect is a kind of jiggling of the picture when there is any motion.
Does anyone know if there some Avisynth script that would correct this? Or some other solution?
nothing that would automatically correct that, unless there is a certain repeating order to it
if you are using avisynth , you have to re-encode anyway, so you could manually re-arrange the frames (e.g. decompress to .bmp or .png, then use ImageSource() to reassemble)
rule out a decoder/playback issue , sometimes b-frames can cause seek errors and decoder lag with some decoders and software. e.g. try other players like vlc, mpchc, kmplayer -
I have tried several players and all the same.
Here is the media info tree
General
Complete name : G:\completed torrents\le vieux fusil dual\Le Vieux Fusil 1975 DVDRip Dual XViD-CG.avi
Format : AVI
File size : 1.07 GiB
Duration : 1h 37mn
Overall bit rate : 1 571 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 37mn
Bit rate : 1 300 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 905 MiB (83%)
Writing library : DivX 6.8.5 (UTC 2009-08-20)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format_Settings_Mode : Joint stereo / MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 89.1 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 504 ms
Writing library : LAME3.97
Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
Audio #2
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 37mn
Bit rate : 128 Kbps
clip.avi -
At first, I thought it was a field mismatch, but it is not consistent in every scene. Whatever the case, this looks like a commercial movie (is that John Hurt I see?)...so buy the movie instead of downloading from pirate sites.
Hmmm..."suffled"....interesting term. -
I actually did want to go that way but the film, "Le vieux fusil" is out of print. To my knowledge, John Hurt is not in the film. The only copy I can find on the used market is region 2 and it is being offered by a collector for $125.00.
If it can't be figured out (and you are right, it isn't consistent) then I don't have to see it - after all, it is only a movie. I am kind of interested, however, as a technical problem. And, yes, as you correctly pointed out in a round about way, I did forget the h in "shuffled." -
Can't repair this with a simple script, the panning shots are smooth and in the correct order, but when it stops you get the misordered frames.
You could spend a week dividing it up into sections and reordering frames...
Or you can get a watchable video, at 12.5 fps, by discarding every second frame:
Get back to 25 fps by faking the missing ones if you want:Code:Avisource("clip.avi") SelectEven()
ConvertFPS just blurs to make the fake frames. You can do get better results using motion interpolation (you need MVTools), I got this to work, though I don't really understand all the parameters, so don't ask me to explain it:Code:Avisource("clip.avi") SelectEven() ConvertFPS(25)
Code:Avisource("clip.avi") EnsureVBRMP3sync() SelectEven() #Double frame rate (12.5 back to 25) global idx1 = 10 global source=last source=changefps(source,source,true) idx1 = idx1 + 1 backward_vec = source.MVAnalyse(blksize=16, isb = true, chroma=false, pel=1, searchparam=1, idx=idx1) forward_vec = source.MVAnalyse(blksize=16, isb = false, chroma=false, pel=1, searchparam=1, idx=idx1) source.MVFlowFps(backward_vec, forward_vec, num=2*FramerateNumerator(source), den=FramerateDenominator(source), mask=0, idx=idx1)
Fixing / Repairing a MJPG AVI video
By DBennett in forum RestorationReplies: 6Last Post: 19th Dec 2010, 07:24 -
Reparing or fixing AVI files
By 1234567 in forum EditingReplies: 26Last Post: 16th Feb 2009, 17:53 -
Fixing AVI Audio - modular distortion?
By 00Billy in forum AudioReplies: 1Last Post: 3rd Nov 2008, 09:27 -
Playing/Fixing a Damaged AVI Video?
By Gildor57 in forum Software PlayingReplies: 5Last Post: 23rd Oct 2007, 20:58 -
Fixing muffled sound on .avi file
By kman0199 in forum AudioReplies: 1Last Post: 7th Jun 2007, 00:40
