Results 1 to 10 of 10
    Jan 2010
    Brazil
    Hello ...
    I have an avi video which was made based on a slide presentation file. After converted the video to MP4, i realized all slide's text become fuzzy. I still can read the slides but it seems like a blur photoshop filter was applied.
    Is there anything with avisynth to improve the focus on this video ?
    thanks !!
    Jan 2007
    Republic of Texas
    Your post is slightly confusing. Did the blur occur only after the avi was converted to mp4, or were the slides never sharp at all?
    It is quite possible that your mp4 conversion settings allocated too little bitrate or had a thumbnail-sized aspect ratio.
    But if the slides were originally shot with soft focus, sharpening filters will only do a slight improvement, but reintroduce noise and grain.
    Jan 2010
    Brazil
    hello filmboss80 ... thanks for your reply...
    The slides are perfect. The avi file created with the slide are nice too.
    The problem happen when i'm converting the avi to mp4.
    would be possible provide some examples using these plugins ?
    i need to say that this is one time work, and i'm not familiar with video world.
  4. What frame size was the source? What frame size was the MP4 file? What video codec did you use? Note that most MPEG codecs encode colors at half the resolution of the luma (grayscale) channel. Small colored text will always be blurry compared to grayscale text:
    Jan 2010
    Brazil
    jagabo ... this is exactly what i'm looking for..... but i have no clue how to identify what you are asking for, so i listed all information for the source file.
    Could you tell me pls how can i walk in direction of the example you have posted ?
    I really appreciate, Thanks !!
    General
    Complete name                    : C:\Video\test\v1.avi
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 177 MiB
    Duration                         : 44mn 4s
    Overall bit rate                 : 562 Kbps
    Writing application              : Lavf52.14.0
    Video
    Format                           : S-Mpeg 4 v2
    Codec ID                         : MP42
    Codec ID/Info                    : Microsoft MPEG-4 V2
    Duration                         : 44mn 4s
    Bit rate                         : 453 Kbps
    Width                            : 368 pixels
    Height                           : 208 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 25.000 fps
    Bits/(Pixel*Frame)               : 0.237
    Stream size                      : 143 MiB (81%)
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 3
    Format_Settings_Mode             : Joint stereo
    Format_Settings_ModeExtension    : MS Stereo
    Codec ID                         : 55
    Codec ID/Hint                    : MP3
    Duration                         : 44mn 0s
    Bit rate mode                    : Constant
    Bit rate                         : 96.0 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 44.1 KHz
    Stream size                      : 30.2 MiB (17%)
    Alignment                        : Aligned on interleaves
    Interleave, duration             : 26 ms (0.65 video frame)
    Writing library                  : LAME3.97
  6. If that is your source small colored text should already be blurry (I'm pretty sure MP42 uses the same 4:2:0 chroma subsampling as other MPEG codecs). What are the properties of your MP4 file? Is it the same 368x208 resolution?
    Jan 2010
    Brazil
    Output file comes out with this conf:
    General
    Complete name                    : C:\Video\test\ex31.mp4
    Format                           : MPEG-4
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 505 MiB
    Duration                         : 44mn 4s
    Overall bit rate                 : 1 604 Kbps
    Movie name                       : ex31
    Encoded date                     : UTC 2010-01-12 05:39:21
    Tagged date                      : UTC 2010-01-12 05:39:21
    Writing application              : Lavf52.31.0
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 3 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 44mn 4s
    Bit rate mode                    : Variable
    Bit rate                         : 1 522 Kbps
    Width                            : 1 280 pixels
    Height                           : 720 pixels
    Frame rate mode                  : Constant
    Resolution                       : 8 bits
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.066
    Stream size                      : 480 MiB (95%)
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : No
    Codec ID                         : 40
    Duration                         : 44mn 4s
    Bit rate                         : 77.4 Kbps
    Channel positions                : L R
    Stream size                      : 24.4 MiB (5%)
  8. You can't enlarge the frame from 368x208 to 1280x720 and expect a sharp picture. Here's an example: at the top is some text taken from a 1280x720 frame. In the middle is that same text after the frame was reduced to 368x208 (precise bicubic resizing algorithm). At the bottom is the text from 368x208 frame after enlarging to 1280x720 (precise bicubic again):
    See how the small text did not regain all the sharpness of the original? Different resizing algorithms give different amounts of blurriness or blockiness.
    Jan 2007
    Republic of Texas
    Bingo. So you're trying to do a blow-up. We did not have that info in the first post. Jagabo's explanation is right on the money. You cannot get high definition out of a low-resolution source. You can only magnify the compression flaws.
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Is 368x208 the best you've got? How did it get that small?
    Can you go back to the original presentation source slides?
    http://www.kiva.org/about
