Hi. I just pulled a video clip off off a DVR used for closed circuit cameras. I just have one camera in test mode and pulled a 3-4 minute clip to USB.
I took it to my computer and none of my video programs will play it. I need to find out if it's just a codec i'm missing or is there something wrong with the file itself.
would anyone be willing to take a look at the file? it's about 2.3M. i can email it as necessary..
thanks
Chris
If the extension is hidden start - > control panel -> folder options ->view ->uncheck " hide extension for known file types then click ok. See if the extension becomes visible.
I have seen raw mpeg files that would not play in windows, can you inport it into virtualdubmod?
i just tried to open using virtualdub, virtualdobmod, and avidemux. All gave invalid file type.... I'll try to contact the manufacturer tomorrow unless there are any other suggestions.
Thanks for the help -
Most security camera DVRs use proprietary codecs. Google the model number to see if anyone has cracked that model.
http://www.kiva.org/about -
Why not post the video file somewhere like megaupload so we can look at it.
MPC with K-lite codec pack won't play ISO movies in Windows 7
By Monsoon in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2010, 21:28 -
Avi codec issues - won't play
By tim_ver in forum Newbie / General discussionsReplies: 6Last Post: 17th Sep 2009, 23:44 -
AVICodec tells me I have the correct codec but video won't play.
By lesbianvirgin in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2009, 01:38 -
xbox360 won't play this avi,, codec info inside
By sance in forum Media Center PC / MediaCentersReplies: 11Last Post: 24th Dec 2008, 12:11 -
Mencoder Batch File - Converts Every Codec type
By peterbuilt in forum Video ConversionReplies: 5Last Post: 28th Jun 2008, 06:41
