    Jan 2010
    Germany
    Hello @ all
    i've killed my BD-P1620... Now i have only a "bluescreen" without anything else.
    the player is extrem noisy if i insert a BD
    it's possible to reset my BD-Player?
    Can i "reflash" my player?
    Please help...
    Oct 2005
    666th portal
    the bios(firmware) - "basic input output system" is sort of self-explanatory. without it working there is no input or output.
    most likely it's dead unless you can remove the firmware chip and have a technician re-burn the proper code into it. (not likely)
    Jan 2010
    Germany
    Thank You very much for Your fast answer.
    most likely i own a brick
  4. (big chance it will not work)did u try to flash it again with the original firmware ?
    Jan 2010
    Germany
    Hello and THX @ all
    i was in contact with Samsung support and they told me that i have to press down and hold the FF (fast forward) 5 seconds without update CD in the drive.
    i've follow the instructions and made the update again. it works! 8)
