You should go to AMD hardware help forums (there are lots around) and ask your question there.
Essentially, you look for the exact make of your motherboard (unless is Dell/Compaq/Gateway crap) and check the website for updated BIOS. Also check the VIA site for the newest drivers.
Caveat - Updating your BIOS (if you don't know what you're doing) may screw up your motherboard. (I just don't want to get blamed if you mess it up.)
A last resort method is to back-up your proggies then re-format the whole drive and re-install Windoze. It's not an exact science... I had to update my BIOS for about 3 versions before my computer became stable.
Hmm, sounds like the dreaded VIA 686b chipset again... man, I for one will be glad when they drop that lousy southbridge and/or SiS 735 motherboards start coming out.
This is the main reason AMD is still getting dirty looks/words from Intel fanatics from time to time - VIA. My response? Make sure you buy a non-VIA board... granted, some people don't experience the problems, and if you know how to update the BIOS and where to check for updates, you'll be ok with a VIA-based board. Anyhow, I strongly recommend checking out http://www.viahardware.com and look up issues regarding large file copying or workarounds for 686b chipset motherboards.
If you don't have a VIA chipset on this board, I'll be VERY surprised. It's a common VIA problem that isn't present with ALi and AMD chipsets right now.
- Good luck!
- H@
any word on those SIS735 motherboards?
Ive been waiting ever since i heard rumors and previews
Anybody know if it will work with Palominos? cause i want the 1.53ghz upon release
im power hungry lol
My New Athlon II
By ocgw in forum ComputerReplies: 15Last Post: 26th Nov 2009, 20:01 -
Encoding - Xp or vista, Athlon or Intel?
By RKDYork in forum Newbie / General discussionsReplies: 6Last Post: 18th Jan 2009, 20:57
