I am going to purchase a Sony 240htz Bravia. One store said I needed to make sure that I use an HDMI cable rated for 240htz and naturally another store said that it doesn't matter. This is going to be connected to a Verizon Fios cable box. Am I correct in going with the 240htz HDMI cable? And another question is that the LCD in question has several HDMI inputs besides the one for the Fios box, does this mean that ALL of the HMDI cables I later add must be rated for 240htz also (i.e., DVD, BluRay, etc)?
Thanks for any help/guidance on this.
Bob
From wikipedia
As long as their are least version 1.3 you are fine
http://en.wikipedia.org/wiki/HDMI
"HDMI 1.3 was released June 22, 2006 and increased the single-link bandwidth to 340 MHz (10.2 Gbit/s).[39][40][98] It optionally supports Deep Color, with 30-bit, 36-bit, and 48-bit xvYCC, sRGB, or YCbCr, compared to 24-bit sRGB or YCbCr in previous HDMI versions. It also optionally supports output of Dolby TrueHD and DTS-HD Master Audio streams for external decoding by AV receivers.[99] It incorporates automatic audio syncing (audio video sync) capability.[39] It defined cable Categories 1 and 2, with Category 1 cable being tested up to 74.25 MHz and Category 2 being tested up to 340 MHz.[57] It also added the new Type C Mini connector for portable devices.[49][100]
HDMI 1.3a was released on November 10, 2006 and had Cable and Sink modifications for Type C, source termination recommendations, and removed undershoot and maximum rise/fall time limits.[40] It also changed CEC capacitance limits, clarified sRGB video quantization range, and CEC commands for timer control were brought back in an altered form, with audio control commands added.[40]
HDMI 1.3b, 1.3b1 and 1.3c were released on March 26, 2007, November 9, 2007, and August 25, 2008 respectively. They do not introduce differences on HDMI features, functions, or performance[101], but only describe testing for products based on the HDMI 1.3a specification regarding HDMI compliance (1.3b [92][102][103]), the HDMI Type C Mini connector (1.3b1 [92][102][103]), and active HDMI cables (1.3c [62][104]).[101]"
Monprice has some great cables at a cheap price
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10240 -
PS2daddy got you the pertinent info (great prices on great cables) but here's a little more:Originally Posted by BobMoyer
1 - The 240hz on your tv has nothing to do with the 340Mhz the article mentions. Two completely different things. The TV is telling you its relative scan rate and the cable is discussing its signal.
2 - Grab the length of 1.3a HDMI cable to your liking. Probably take a couple of days to come in. WELL WORTH the wait.
3 - Each HDMI port handles their signal, and usually settings, independantly.
4 - Don't let any store sales morons talk you into Monster anything. Cables, power strips, UPSs. Actually, I wouldn't by anything at any walk in store. The likes of monoprice and bluejeanscable will take care of you and you'll save a lot and won't give up anything.
A buddy of mine went out and bought himself a nice 46" Samsung (and a BluRay setup) for a respectable price. Probably could have found cheaper online but he got a great TV, mount and setup at a good sale price at a local store. Easy enough for returns if needed. That part went well.
However, he let his wife take care of the cabling while he went out back to get this setup for delivery. She spent over $400 on cables. When he showed me what he got and I told him it could have been about $60 he went through the freakin roof.
Couple of HDMI cables for his cable STB, the BR player, and a power strip. $100+ for cables? Unbelievable.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
neomaine,
Thanks for that additional info. One of the salesman (at Sears, of all places), basically told me the same thing. All of the other stores pushed the cables for $100+.
Bob
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33 -
Question on HDMI cable format
By Kev90 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2010, 23:19 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
HDMI cable seems worse than RBG cable
By BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 18:27
