Results 1 to 9 of 9
    Aug 2009
    Hi everyone,
    I want to burn an ISO file to dvd. But when I loaded the ISO file, it says, "INIT ERROR: "VTS_02_0.IFO" contains bogus data and can't be repaired". I have burnt an ISO file before and it worked fine...
    Here's the log file:
    2010-01-09 18:21:17 Error BURN: INIT ERROR: "VTS_02_0.IFO" contains bogus data and can't be repaired.
    2010-01-09 18:21:16 Info BURN: Scanned files #26, folder #2 - total size 3575926784 b. (3.33 Gb.)
    2010-01-09 18:21:16 Info BURN: Inserted media type : DVD-R
    2010-01-09 18:21:16 Info BURN: Write started
    2010-01-09 18:21:14 Info Disc name: "TNKK 9"
    2010-01-09 18:21:14 Info Burned folder: "C:\Users\ACW\Videos\TNKK 9"
    2010-01-09 18:21:11 Info BURN: New media (DVD-R) inserted. Burning layer is ready to write
    2010-01-09 18:21:09 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
    2010-01-09 18:21:09 Info BURN: Drive has IDE-ATAPI physical interface
    2010-01-09 18:21:09 Info BURN: New Drive selected : 1:0:0 - TSSTcorp DVD+-RW TS-L632H D400 [D] (Ide)
    2010-01-09 18:20:48 Info 36 Menu templates loaded.
    2010-01-09 18:20:47 Info BURN: New media (DVD-R) inserted. Burning layer is ready to write
    2010-01-09 18:20:44 Info BURN: 1 writer(s) found.
    2010-01-09 18:20:44 Info BURN: Loaded DLL "C:\Program Files\VSO\ConvertX\3\vso_hwe.dll" [3.2.6.409]
    2010-01-09 18:20:44 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
    2010-01-09 18:20:44 Info BURN: Drive has IDE-ATAPI physical interface
    2010-01-09 18:20:44 Info BURN: New Drive selected : 1:0:0 - TSSTcorp DVD+-RW TS-L632H D400 [D] (Ide)
    2010-01-09 18:20:44 Info BURN: Using Patin-Couffin driver Version 1.37, Internal revision 37 Async. Access mode
    2010-01-09 18:20:44 Info Supported instruction set: sse3
    2010-01-09 18:20:44 Info Number of allocatable threads: 2
    2010-01-09 18:20:44 Info Tuning Performances for Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz with 2 core(s) CPU
    2010-01-09 18:20:43 Info System default language : English (United States)
    2010-01-09 18:20:43 Info User default language : English (United States)
    2010-01-09 18:20:43 Info Version : 3.7.2.188
    2010-01-09 18:20:43 Info ExeName : C:\Program Files\VSO\ConvertX\3\ConvertXtoDvd.exe
    2010-01-09 18:20:43 Info OS : Microsoft Windows Vista Home Premium (Build 6001: Service Pack 1)
    2010-01-09 18:20:41 ---- ******************** Log session start 2010-01-09 18:20:41.196 PID
    Thanks for any input
    Oct 2005
    666th portal
    you could try imgburn, but why you'd want to burn a disc with bad data is beyond me. i'd try extracting the video-ts folder from the iso and fix the dvd first.
    Aug 2009
    aedipuss, thanks for the reply! So the movie file is corrupted? The previous part burnt successfully onto a DVD and plays on my DVD player. So I have no idea why the other parts are bad.... :X
    Is it fixable like you said?
    EDIT:: It's weird though cause all the movie files are viewable on my computer...
    Apr 2004
    Miskatonic U
    What are you using to play them back ? Some software is far more tolerant of corrupt data than something like a DVD player will be.
    Read my blog here.
    Aug 2009
    guns1inger, I use GOM player to play it them.
    Aug 2009
    So there is no way to fix these dvd files?
    Apr 2004
    Miskatonic U
    I would start by mounting the ISO with DaemonTools, and copying the content to folders on your HDD.
    Attempt to play the DVD as a DVD by opening the first IFO file and see what happens. Go through all the menu options to make sure all the titles work.
    If everything seems OK, try burning from the folders instead of the ISO. Imgburn, build mode, select the Video_TS folder and Imgburn will take care of the rest.
    If you still get the same error, use IFOEdit to build new IFO files and see if that solves the issue.
    Read my blog here.
    Aug 2009
    ^ Thanks guns1inger, I will try out your methods.
  9. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    extract the files to your hard drive. open them with pgcedit to check...let it fix any errors.
    burn with imgburn and nothing else
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
