Will any of these motherboards handle the RAM listed. I see that they OC to 1800 but not sure if thats the limit or not.
Motherboards: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200022+1388027176+1387...e=&srchInDesc=
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231267&cm_re=G.SKILL_3GB_%283...-267-_-Product
Detailed answer would be great, I'm trying to learn as much as I can. Thank You![]()
If you want detailed information go to a good overclocking forum site like overclock.net.
AMD memory:
http://www.overclock.net/amd-memory/
INTEL memory:
http://www.overclock.net/intel-memory/
Overclock.net is a great forum site to learn about overclocking cpu, gpu and ram. GSkill has models that overclock better than others. If you want good overclocking ram there are other brands such as OCZ, MUSHKIN & CORSAIR.
WD TV capability
By jayantadak in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Apr 2010, 23:00 -
Can't find RAM compatible with Motherboard
By AuroEdge in forum ComputerReplies: 5Last Post: 15th Jan 2010, 22:40 -
PC2100 ram in a motherboard rated for PC2700?
By freebird73717 in forum ComputerReplies: 2Last Post: 18th Jul 2009, 10:23 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 16:54 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 22:25
