    Jan 2010
    Australia
    Do you know if you can fix a USB cable that has been cut off at one end by splicing a new one on ?. I can't easilt just replace the full cab as its in the wall of the house and hard to get out ?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    http://www.kiva.org/about
    Jan 2010
    Australia
    Originally Posted by edDV
    Thanks. It need it for Type A end of my cable. I'm note sure if its female or male ? Ist the end that goes into computer usb slot's. Sounds like either way a solder job is that right ? just easier with these connectors.
  4. Member edDV's Avatar
    Mar 2004
    All types of connectors are available with solder pin connections. Some are wall mount.
    You can buy USB cables with any combination of connectors.
    Total length of USB is limited to ~5m. You may need a repeater.
    http://www.buy.com/retail/product.asp?sku=209856997&listingid=36816083
  5. Male "A" connectors are used on cables that go to a PC, female should be used on wall receptacles. "B" connectors are used on peripherals.
    Feb 2004
    Australia
    Its simple as remembering female = receptacle / socket and male = plug
    There's type A "13.1(W) x 5.5(H) mm" and type B "5.6(W) x 3.2(H)mm"
    Parts :
    1 : A wall bracket with an A type interface receptacle (makes it appear neater)
    2 : Usb cable with A type plugs on each end
