A lot of encoders seem to encode to 128kb joint stereo and there is enough factual data/debate out there, that states the surround signals are "killed",but 128kb at stereo preserves the signal better. My question is, if you remix 128kb stereo to 192kb is it of benefit compared to remixing from 128kb joint to 192kbits either joint
m/s stereo or stereo.
Or rather is it that the "damage" is done in the first place and signal/frequencies are lost irretrievably when encoding to 128kb from a Dolby source in the first place, whatever form you use at lower bitrates?![]()
What's gone is gone. If the original file is damaged (i.e. the audio content is damaged) and you can restore some of it through filters then there might be a benefit, however if you are simply re-encoding at a higher bitrate, all you get is a bigger file that sounds the same.
Read my blog here.
You can't get back what you don't have. But you could put the audio in a audio editor and 'tweak' it a little with the filters, add bass or clean it or change the response curves, then save it out as 192K and maybe get less quality loss than going back to 128K after filtering. Audacity has done wonders for some audio files I have modified.
As I suspected no benefit. The only real time it worked out qualitywise for me was remixing a mono track to stereo 192 or converting the odd track to Dolby 2.0 with TMPGenc after using a few filters etc.
Magix Audio Cleaning Lab has some great cleaning ability with its filters which can run automatically and it gives data graphs of tracks. Audacity I have used and is good as well. Thanks guys!
What will the benefits of Ultraviolet be? I'm already signed up now what?
By yoda313 in forum Video Streaming DownloadingReplies: 4Last Post: 15th Oct 2011, 01:28 -
MKV to AVCHD - problem with MP3 audio track?
By magnu in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Nov 2009, 07:25 -
DVD concert audio to MP3 (Individual Track Please)
By c1steady in forum AudioReplies: 8Last Post: 11th Apr 2008, 14:19 -
Automatic MP3 track numbering
By UncleBose in forum AudioReplies: 2Last Post: 8th Aug 2007, 01:54 -
MP3 track - low voice level
By Digiface in forum AudioReplies: 5Last Post: 30th Jul 2007, 18:05
