Thx for your help..
yap,that waht I did in my experiment,I capture,I save a avi format,then (I opened that file with panasonic mpeg encoder,I save in mpeg2 format,then I open that file with Nero and I burned the cd,like 20 second and then I played in dvd,work fine,after that duhhhhh!!!!! I red my dvd manual and there is!!! support dvd,vcd,mpeg2,etc,etc,, my dvd brandname is
Pioneer DV-525
Good luck.
Rigo.Rigo.F -
yes the 711 plays vcd, as well as svcd, though with svcd to hear sound you need to set the audio under setup to pcm or something like that. Anyway, I had a 711 for about a year plus and I got it because ot would play vcd.
I will say that the 711 seems a bit finicky on the xvcd stuff. Though on straight forward vcd and svcd plays perfectly.
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 08:48 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
how to encode MPEG4 to play on a phillips DVP-642 player
By thejunkman12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2008, 09:32 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 12:47
