Good day all,
In trying to upgrade firmware 15-17 on my new PHILIPS DVP5996K/98, I killed the player, although there in no excuse I must admit the Philips site info. is somewhat misleading, and this is strictly to help others from falling in the same hole;
Since there were no action; USB flash drive wasn't blinking + no on-screen response, just upgrading for a loong while, I removed the USB drive..
It is stated; 5. A dialogue will now appear - follow the instructions to update the software of your player. Observation; (There was no dialogue, just "upgrading", for a long while )
It is stated; 6. When the disc tray is ejected, you may remove the USB device. Observation; ( the moment you plug the USB flash drive in the tray ejects!)
I would truly appreciate any input/suggestion on how to revive this player, if any.
Regards
Results 1 to 10 of 10
When I upgraded the firmware on my $700 Philips DVD recorder (many many many years ago) it said DO NOT TOUCH the machine until the firmware update is complete and the screen says "complete". I left the house for an hour.....went shopping....just to make sure i didn't mess up my machine.
I guess you didn't follow that advise?
Try the exact same firmware update again and hope that it works. If that doesn't do anything, try to install an older version - if you can find one.
You can pay Philips to repair it, but the cost might exceed the cost of a new player. If your player is still under warranty you might be able to get Philips to repair it, but I don't know what their policy is on this type of thing. If they make the firmware available to the public, they might not view a botched upgrade as something to hold against you. -
jiman98,Originally Posted by jman98
Thanks for the suggestion but my problems are more complicated than that; the player is unresponsive period (Only PHILIPS on LCD) and to make matters worst the player was bought in the US and shipped abroad...
Regards. -
the only way to fix a bad flash is to remove the bios chip and have it reflashed in a chip burner. that would require someone with the proper equipment and possibly required de-soldering the chip form the motherboard and then re-soldering it back. most likely cost more than the unit if you could find a tech to do it.
Many thanks aedipuss, you are right, if this is the only way, it is really not an option..
I extract from my player firmware. It's for 5990/12 but with this you can get back HDMI!!!!. Use a serial cable + MTKTool_2.37 (from rar file). After recover, rename upgrade firmware (DVP5996K_98.bin) to DVP5990_12.bin and make update.
http://rapidshare.de/files/48960470/5990.rar.html
Good luck! -
vb6rocod,Originally Posted by vb6rocod
Many thanks, I'm now hopeful but still need your help please;
Could you be a little more specific with exact details on how to do this;
A) Connecting the serial cable; the DVP5996k has no serial connection, could you explain please?
B) Once (and if I'm lucky.) it is connected, how do I load the firmware using the MTKTool please?
Kindly forgive my ignorance in this matter.
Regards. -
vb6rocod,
Ok, did some research and have a better understanding now;
A) My PC doesn't have a serial connection, it has USB, HDMI, VGA, eSATA, Fire Wire, ADSL and one Expansion Port 3, what cable/connection should I use please?
B) Can the actual firmware upgrade (5996k/98 V17) be used?
Many thanks.
Bin Laden killed!!!
By deadrats in forum Off topicReplies: 1Last Post: 2nd May 2011, 12:03 -
This killed me!!!!! Everyone need's one of these!!! LOL!!!
By Noahtuck in forum Off topicReplies: 6Last Post: 7th Aug 2009, 22:18 -
Philips DVP5996K & HD Videos
By kouras in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Jan 2009, 09:26 -
Killed my DVD recorder
By Kschossi in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Mar 2008, 23:57 -
Australia's Crocodile hunter killed
By MeDiCo_BrUjO in forum Off topicReplies: 42Last Post: 4th Sep 2007, 14:50
