I have a file here that is in mpeg 2
it was captured off a HD tape/camera
video is 1536x1080
video bitrate is 25000k
frame rate 29.97
audio format mp3
audio bit rate 384k
this is the first time I try and convert a HD file
but as it is now I cannot open this file in adobe premiere
is there a simple way to convert this into an adobe premiere usuable .avi file?
thanks
aedipuss did what you asked here are the results
General
Complete name : C:\movie1.mpeg
Format : MPEG-TS
File size : 6.16 GiB
Duration : 33mn 47s
Start time : UTC 2009-11-12 03:38:37
Overall bit rate : 26.1 Mbps
Maximum Overall bit rate : 33.0 Mbps
Encoded date : UTC 2009-11-12 03:38:37
Video
Menu ID : 100 (0x64)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High 1440
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 33mn 47s
Bit rate mode : Constant
Bit rate : 23.9 Mbps
Nominal bit rate : 25.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : Component
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.513
Stream size : 5.64 GiB (92%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 33mn 47s
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 92.8 MiB (1%)
not sure what make the cam was all we know is it was a hd cam -
virtualdub cannot open the original since it is a .mpeg
handbrake can only output to mp4? I need to convert this file to a .avi or an adobe premiere friendly output
help converting WMV to AVI
By user943 in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 10:39 -
Converting .WMV to .AVI - What should I use to do this?
By Hank Kinsley in forum Video ConversionReplies: 3Last Post: 16th Oct 2008, 04:54 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 04:15 -
CONVERTING FROM AVI TO WMV or RM
By sunsound in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 03:17 -
newbie: converting wmv to mov, mpeg, etc. = loss of audio
By adambolo in forum ffmpegX general discussionReplies: 4Last Post: 17th May 2007, 10:27
