Page 1 of 6
1 2 3 ... LastLast
Results 1 to 30 of 151
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    I have now finally decided to upgrade our forum to vBulletin. I was going to do it last year but had some problems with the layout and importing from phpbb but with the new vBulletin 4 it works better.
    See how it looks like at http://forum3.videohelp.com/ . You can also login using your current username and password.
    The layout is pretty similar to this one and you can also choose a blue layout or use vbulletins default(at the bottom left). I will probably upgrade this month even if I hadn't finished all tweaks yet.
  2. DECEASED
    Jun 2009
    Heaven
    The upgrade will be most welcome
    even though it still needs some serious tweaks:
  3. Just wanted to say thank you for all that you do!
    I depend on this place a LOT.
  4. Finally preview reply in real time!
    I only surprise this option only now available
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the file attachment rigmarole seems a bit awkward.
  6. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Great Job....Looks Sweet...
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I will try add a quick uploader so you have don't mess around with the flash uploader.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I'm afraid of change....
    But it looks cool.
    Thank You Baldrick.
  9. I like change, but I don't like the new icons and their size.
    Originally Posted by jagabo
  10. Originally Posted by aedipuss
    I agree, I like phpbb better.
    Hey Baldrick will you conduct a class for us old timers?
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Okey. Login. Click on topic. Click reply. Type "Use AVStoDVD". Click post. Done.
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    keep going and include attaching a file...
  13. I selected the blue and center, clicked change
    Nothing changed, still the default
    IE8 with and without compatability mode
  14. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you go all the way to the bottom the change defaults works. the one on the side didn't for me either. you can even get it to look like this :-\
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    I will make the switch on tuesday, it should only take some hours BUT it will take some days until everything runs fine. And I will also keep fine tuning the layouts(standard and blue) for some weeks.
  16. Member yoda313's Avatar
    Jun 2004
    The Animus
    edit - never mind - didn't fully read the post......
  17. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Can we have the last post link show the post instead of "Go to last post", like we currently have?
    Buy My Books
  18. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep! I'm working on it right now.
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    Does this work?
  20. Member olyteddy's Avatar
    Dec 2005
    I like the V-Bulletin upgrade. Looks nice. Glad you kept the same basic layouts. I do miss the 'hover spots' for post count and system specs however.
    Never mind the hover spot beef. Hadn't played around enough to see the little 'puter icon under my avatar.
  21. Originally Posted by olyteddy View Post
    Look under your avatar...and hover over the magnifying glass and the computer.
  22. Anyone else lost the ability to "view my posts"? Anything I posted prior to today does not come up when running the "all my posts" request in the new "view my" drop-down. This used to be a one-button function, convenient for auto-tracking threads of recent personal interest and checking what I might have posted in similar recent topics. Will this "view all my posts" search eventually work again under the new"view my" menu? Its doesn't right now...
  23. Originally Posted by orsetto View Post
    I have to rebuild the search index before you can view all your posts.
    It will take some DAYS until everything runs fine. I have tons of fine tuning to fix.
  24. And the forum will be a bit slow for some days.
  25. Mod Neophyte redwudz's Avatar
    USA
    If you are interested in Vbulletin operations, the manual is available here: http://www.vbulletin.com/docs/html/
    I'll probably be spending some time in the 'Moderation' section. lol.
  26. Originally Posted by redwudz View Post
    I will fix your super moderator status later this night....and give some hints how to ban spammers. .
  27. And Admin=Baldrick.
  28. Mod Neophyte redwudz's Avatar
    USA
    No problem. I'll do some other projects today and check back in later. (I like the spelling checker. Same one I use anyway.)
  29. Member bendixG15's Avatar
    Aug 2004
    Thanks for the upgrade ...........
