Hello everybody!
I want to upscale SD video file to HD. So I used Distort -> Transform but got problem with the exported file.
The exported file looks jumpy and I see duplicate frames during playback. It sounds like wrong interlace setting.
But I set everything correctly. Here's the detail:
Premiere CS4
SD video file: MPEG2 720x576 25fps interlaced
HD project: XDCAM EX 1080i 50i (HQ)
Export setting: MPEG2 HDTV 1080i 25 HQ (I tried both Upper and Lower)
Tell me if you need more information![]()
Premiere probably misidentified the field order of the source. You need to convince it your source is the opposite field order. In many programs you do this by right clicking on the source in the timeline and selecting properties or field order settings from the context menu.
Use the same sequence settings as your source; in this case it's not xdcam.
Change the field order in those sequence settings, if the preview is correct, then keep that field order in the export settings
Upscaling isn't very good to begin with - you can't recreate details, you only waste space as more bitrate is required for the larger file. It's usually better to let your player/TV upscale. Also, PP's algorithm is very poor. You're better off using other software if you insist on upscaling. Also, resizing interlaced content is tricky to do properly. -
Yes, it exists in After Effects CS4 but not in PremiereOriginally Posted by jagabo
Upscaling performance to 1080i/720p
By alexh110 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Dec 2011, 17:02 -
Twixtor for Adobe After Effects CS4
By Tahlos in forum EditingReplies: 4Last Post: 5th Oct 2010, 20:57 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Exported 1080i Premiere Pro CS4 sequence - out of sync
By nitrous in forum Software PlayingReplies: 9Last Post: 18th Oct 2009, 12:16 -
1080i true interlaced source to DVD
By nebbish_2112 in forum DVB / IPTVReplies: 37Last Post: 18th Nov 2007, 10:31
