  1. Gamer and Builder HotDamn!'s Avatar
    Nov 2009
    I have an ASRock K10N78 motherboard that has NVIDIA GeForce 8200 on board graphics. And it says it has DirectX 10
    http://www.asrock.com/mb/overview.asp?Model=K10N78
    I also want to upgrade and get another motherboard and graphics card that will be OpenGL compatible.
    My question's are what is the difference between the two? Which would be best? Can I somehow get OpenGL to run on my current system? (I run windows XP pro.)
  2. Member Soopafresh's Avatar
    Jan 2004
    Not that many apps take advantage of OpenGL - 3D CGI creator apps like Maya, 3DsMax, AutoCad are optimized for OpenGL
    The most popular OpenGL cards are the Nvidia Quadro series - pretty expensive. Unless you have a specific app that wants OpenGL, spend your $ on a good DirectX card.
    OpenGL cards tend to be very good for the apps above and not great for DirectX apps (the game world).
    "Quality is cool, but don't forget... Content is King!"
  3. Gamer and Builder HotDamn!'s Avatar
    Nov 2009
    Thanks. I just read up one some stuff about it and found what I was looking for a lot faster than I thought I would.
    I guess I just wasnt 100 % sure on exactly what they were.
    Feb 2004
    Australia
    OpenGl support was pretty well across the board after version 1.5 release
