yeah I know they can coexist but I couldnt find mvtools only the mvtools2. the avisynth site that has em on it wont open for me. says it down or somethin.Originally Posted by poisondeathray
I think I already got all those from that thread. It was the requirements folder right? had all kinds of dll files in it?
Results 61 to 79 of 79
Yes. There should be mvtools and mvtools2 in the folder (I think), and one of the mvtools has a MT branch (multithreaded) , that's the dll you want if you are getting that error. The dll has to be in the avisynth/plugins folder to autoload, otherwise you have to manually load it (including directory paths)
yeah, I have it in the avisynth plugins. not all of them are autoloading even when in it but it doesnt bother me to specify the directory.Originally Posted by poisondeathray
also heres the sample I mentioned earlier. no opening or closing songs and not the mist episodes so you can see the actual color and look in it. http://www.mediafire.com/?eyjglzqlvjn
I guess I gotta keep lookin for mvtools then if I need em both. -
If you have mvtools.dll in the plugins directory, and you still get that error, you are using the wrong version (you are using the non MT version)
Go back to that plugins collection and find the MT version and replace the mvtools.dll
You have to close avsp or vdub and re-open it to let it autoload when you added new dlls to the plugins directory -
Nightshiver saidOriginally Posted by poisondeathray
That's because mvtools2 doesn't have MvAnalysemulti. You need the josey_wells version. Use this version: http://www.mediafire.com/?nndnztohoze -
That's probably the same mvtools.dll that came in the zip file collection under the MT folder
Your most recent clip example is more like the intro example in terms of color, saturation, dot crawl, but has more noise in general and a lot more noise in a few frames (around frame 628 or so). You might want to filter those separately, because a heavy filter will destroy detail from the other frames. A lot of anime sucks for this. You almost have to go through each frame indivudually to check. -
Well I just uninstalled and reinstalled my avisynth sith the new 2.6.0 alpha 2 version [I had 2.58] so Im gonna redo my plugins folder and see if that fixes any of the problems I was having. I couldnt get some functions from his or your scripts to work and I was always getting errors for some types. Ill fill you in on it later if I notice any changes. (Care to put your entire plugin folder into a zip and send it?)Originally Posted by poisondeathray
Yeah that noise gets really annoying because removing it removes line details and stuff at times. Its probly the number one annoyance to me. I better start practicing filtering specific parts with different filters so I get it down. Up till now Ive only done filter the entire thing with one script.
oh and someone on doom 9 claims this is their script they use usually.
My usual script with variations:
http://forum.doom9.org/showthread.php?p=1361705#post1361705 -
I wouldn't worry too much about functions that won't autoload. Some won't autoload by design and have to be imported, and some that should autoload won't (for me anyway). Just import them instead, changing the .avsi extension to .avs if necessary:Originally Posted by darkdream4
Import("C:\Path\To\InPaintFunc.avs")
Of course, you've run into one of the other reasons these functions sometimes won't work - having the wrong version of a needed DLL, and it's not only frustrating, but infuriating. For me anyway. Sometimes the needed information/version is given in theAviSynth Wiki if not in the included doc for the function or in a thread at Doom9. Anyway, if you haven't discovered it already, most (but not all) of the functions can be found here:
http://avisynth.org/mediawiki/External_filters -
A few people have reported stability and issues with 2.6.X , I suggest you stick with 2.58 until 2.6.X becomes more mature.Originally Posted by darkdream4
If you post the specific errors that you're getting I can try to help you out.
The problem I have with sharing my entire plugin folder is I have unzipped and modified some of the original files, and you're not supposed to distribute the filters without the full documentation and sources (in fact you're only supposed to download them from the original URL source). There could be errors and issues with versions etc... and many of the programmers get upset about this
My plugin folder is a complete mess. I recently started a new practice of backing up the original zip in a separate drive (I make copies if I upgrade versions) , and keeping the unzipped file in a labelled subfolder within the plugins directory so i know what version it is (some dll's have version identifiers if you right click it). I'm sure everyone has their own way of organizing things. So I do have unmodified backups of the newer original filters that I use within the last year or so, and I'm happy to upload the unmodified original zip of the versions I am using. I think the zip file collection from the AnimeIVTC thread has newer versions than the ones I am using , however.
And another link to filters to complement manono's link above:
http://avisynth.org/warpenterprises/ -
not sure, i think mt_masktools , the v2.x branchOriginally Posted by darkdream4
Post the full error message and script line -
I got it working.Originally Posted by poisondeathray
That animeivtc has been giving me major problems. everytime I use it in AvsP it practically freezes the program so it takes like 30 seconds before I can even touch it or do anything in it. Its slows everything down beyond belief. when I use the aa=4 like nightshiver said to instead of aa=0 like you, it doesnt even work at all, it crashes any program I try to use it in. -
Do you mean all the filters? or just mpeg2source and animeivtc ? Nightshiver's script is quite a bit slower because of the motion based filters are cpu heavy when they do their vector analysis. aa=4 does a whole bunch of things like warpsharp, line dark, anti aliasing , but if you're missing a plugin it should say so, not just crash.Originally Posted by darkdream4
Are you using the 2.5.8 avisynth version? -
yes I went back to the 2.5.8 version the moment you mentioned 2.6 has issues.Originally Posted by poisondeathray
and the only thing causing the problem is aa=4 when I make it 0 it works fine. even in his script.
the maker of that animeivtc also told me I had an autoload script with the extension avs and needed to make it avsi. that fixed the limitedsharpenfaster problem.
This is what I gave him to look at.
http://img191.imageshack.us/img191/1263/plugins3.png -
Well I gotta admit, this one turned out better than any of the scripts I tried messin with so far.
http://www.mediafire.com/?4mznzddjzw4
The only thing I really want out is the bits of noise around the japanese text and at the very end that fight scene you can see blocks/cubes pretty damn easily. Other than that its not too bad I guess. Ill get em out eventually when I feel like playing with it more. as for now, an entire week of reading and trials makes me want a small break lol.
anything else you would fix in it? -
Compare your script to the encoded file in tabs in AvsP. If the .avs looks much better then you know it was from the encoding & encoder settings
If the filtered .avs already has blocking and edge noise around the text, then use a deblocking filter , and other filters to get rid of that edge noise
I suspect it's a combination of both -
Yeah, thanks for all the help on all of that stuff.
I think now that I know how to use AVISynth at least, Id like to learn how to encode with h.264 instead of Xvid. I would prefer an h.264 video put into MKV with dual audio and soft subtitles.
Do you have any suggestions on freeware for making VOB into h.264? Handbrake does it but I get the feeling theres better ways to do it. Id like to encode my h.264 file on my own and use MKVMerge with the audio tracks and subtitles instead of have Handbrake encode and make it MKV for you. -
Just like there's a lot to learn about avisynth and filtering , there's a lot to learn about encoding and settings for different sources, and how encoders behave
You can trade off ease of use for customizability when using easy to use GUI's like handbrake. Anime requires different settings than live action. Different sources require different settings for best results. There's way too much to go over in 1 post. I can tell you , in general, most people use lower psy settings, lower AQ settings than default for "traditional" type anime, higher number of b-frames because anime is very compressible. But CGI type anime is different and highly detailed, so you would use different settings.
You can start by reading the settings wiki, but they won't make much sense until you start encoding and reviewing and experimenting to learn how the settings work.
http://mewiki.project357.com/wiki/X264_Settings
The new megui builds (see the doom9 megui patched thread) are better now, and is probably the most comprehensive solution, but also the most confusing to use. Handbrake, ripbot264 are easier to use, but don't allow for full control. Experiment with the GUI's until you find one you like. The command line is easy to use now with the preset system in x264
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Have I made the quality too Good?
By criddle in forum Video ConversionReplies: 1Last Post: 4th Apr 2009, 04:37 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Has Microsoft Ever Made A Good (Windows Media)Encoder?
By hech54 in forum Video ConversionReplies: 7Last Post: 6th Jul 2007, 00:27 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 01:35
