Hello, I am using DVD Shrink with Imburn. After I open a dvd movie, I select target backup to have Imgburn burn it after DVD Shrink extracts the movie. I was wondering is there a way to set it up so I can do a one-click option and not have to sit there and wait until DVD Shrink finishes encoding, then click "Write image file to disc" in Imgburn.
In the previous DVD Shrink + Nero, all I had to do was select Nero burning option, and DVD Shrnik finishes encoding and then automatically opens up Nero to burn. That way, I can put in disc and come back and everything will be done.
Have a look here..
http://forums.afterdawn.com/thread_view.cfm/521885 -
bodyslide, ive installed the exact versions here. I am asking how to automate it so Shrink automatically oepns Imgburn one continues burning without additional clicks afterwards. I have 2 dvd drives. The version of DVD Shrink + Nero was able to do automated before. Not sure if Imgburn is set up to do that?
Maybe some one else can help, I have never done the full automated like you need. Good luck
What version of Shrink?
Select to write with dvddecrypter it should be automatic. -
According to Redwudz this version will do it:
https://forum.videohelp.com/topic377565.html#2036383
I use DVDDecrypter to burn automatically.
right-click relatively slow
By alintatoc in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 11:28 -
Right click (mouse) not working?
By jh1966 in forum ComputerReplies: 8Last Post: 3rd Feb 2010, 01:21 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 22:20 -
One-click ripper and converter that has quality?
By exon in forum DVD RippingReplies: 1Last Post: 31st Jan 2009, 03:44 -
Click encode and nothing happens.
By painofmind in forum ffmpegX general discussionReplies: 7Last Post: 5th Jan 2009, 15:26
