hey a new trick showed up for win7 32bit. a way to get a heck of a lot of the controls available in one folder. this is only for win7 32bit & 64bit and vista 32, trying it on other o.s.'s may crash your machine
make a new folder and name it - GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
that's it. the folder icon will change and then check out what's inside.
[edited to reflect OS's supported]
Results 1 to 13 of 13
hehe - you're one crazy dude. i sure hope you didn't try it on a production machine. i posted the warning because there are reports of the trick blue screening win7 64bit systems.Originally Posted by JohnnyMalaria--
Works good an my Win7 x64 machineOriginally Posted by aedipuss
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Works in 7-64, but not in Vista 64.
That was made for Vista, called Master Control Panel.
Thanks for bringing this up, aedipuss.
btw, you can try other names, instead of GodMode
**NB The ‘godmode’ works with both the 32 & 64-bit versions of Windows 7, Vista 32-bit, Windows Server 2008 32-bit should also work. ** However, it is known to crash 64-bit versions of Vista : you may need to boot in safe mode or to the command line to delete the folder. Be warned..
There is a workaround for Vista 64, where you can get Master Control Panel also, Google for it. -
Cool trick, but yes, you may want to avoid incurring His wrath, as He may have a few computer tricks of His own in mind for you.Originally Posted by NoBuddy
seems redmond released a list of other "special" tags to create other shortcuts.
http://www.aviransplace.com/2010/01/07/windows-7-has-lots-of-godmodes/
{00C6D95F-329C-409a-81D7-C46C66EA7F33}
{0142e4d0-fb7a-11dc-ba4a-000ffe7ab428}
{025A5937-A6BE-4686-A844-36FE4BEC8B6D}
{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9}
{1206F5F1-0569-412C-8FEC-3204630DFB70}
{15eae92e-f17a-4431-9f28-805e482dafd4}
{17cd9488-1228-4b2f-88ce-4298e93e0966}
{1D2680C9-0E2A-469d-B787-065558BC7D43}
{1FA9085F-25A2-489B-85D4-86326EEDCD87}
{208D2C60-3AEA-1069-A2D7-08002B30309D}
{20D04FE0-3AEA-1069-A2D8-08002B30309D}
{2227A280-3AEA-1069-A2DE-08002B30309D}
{241D7C96-F8BF-4F85-B01F-E2B043341A4B}
{4026492F-2F69-46B8-B9BF-5654FC07E423}
{62D8ED13-C9D0-4CE8-A914-47DD628FB1B0}
{78F3955E-3B90-4184-BD14-5397C15F1EFC}--
Tried it on Windows 7 32-bit and works great! Thanks for sharing with us.
n.p. - i was just passing it on from something posted on /.
here's a small program from a tech site that creates all the g-mode folders for you, no more copying and pasting...
as an aside does folder #16 work for anyone? i get a regular folder instead of the region controls. it's got the correct code. not that i will miss them anyway.
gshultz_v7r_godmode.zip--
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
16 more Win 7 "God" modes
By deadrats in forum ComputerReplies: 95Last Post: 11th Jan 2010, 00:48 -
"portable" software and Win7 problems
By Toastie in forum ComputerReplies: 0Last Post: 13th Dec 2009, 06:54 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 10:03 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02
