newbie- I have dvd disc in TS-video when I click on properties. I want to get it into a form that I can put video on my website and on Youtube. do i need a ripper or converter and which one? so many online, i have no clue which one to use- going crazy- is there a simple machine I can buy? I must get project done. I would attempt to edit some parts of the video on windows movie maker. This is all so complicated and I have wasted hours and hours and getting nowhere. thanks.
I forgot I have windows xp
Use vob2mpg and import the mpg in wmm or windows live movie maker. You probably need a mpeg decoder installed, ffdshow may work. Export as wmv and upload to youtube.
Or if you just need to cut use mpg2cut2 to cut the mpg from vob2mpg. Upload the new mpg file to youtube.
Or try/buy a mpeg/dvd editor like mpeg video wizard, you can import the dvd vobs directly and edit. -
hi and welcome to the forum.
vob2mpg is a program to convert a dvd to mpeg-2. most likely you want to select 1 video and 1 audio stream to rip. once it's in mpg format there are lots of programs to convert to an online type video like mp4. handbrake and mediacoder are just 2.--
Hi-Originally Posted by aedipuss
this sounds so complicated for a non-techie. WHat is this 1 video and 1 audio stream. Is that a thing I click on that vob site. So do I need ripper or converter? THe tools you mentioned seemed like lots of steps. What if I just want to take the dvd in it's TS_ format and just change it into mpeg4 or wmv or whatever form that would let me put on my website.
Then if I did that, could I edit at that point .
Ever heard of aiseesoft software?
Is these 3 steps necessary. Ripping and converting and editing or does one software do all I want to do? thanks again.
I read some reviews and some said stuff that was complicated. -
Welcome the wonderful world of digital video. If you want simple, find another hobby. There are basically two ways to work with digital video - the easy way, and the right way. Only one way produces a quality outcome. I'll let you guess which is which.
However if you are prepared to put a little effort in up front, you will quickly find that what seems daunting and complicated now is soon second nature.
You will find that there are literally hundreds of video conversion programs out there that promise the world at a click. Most of them use the same back end tools that many of the more complicated tools use (public domain, open source software), but they put a pretty interface on them to hid the complexity. They also use low quality presets because they have now real idea what working with video is all about. Aiseesoft software is just another one of those.
Trust me, if you are going to do this more than once, listen to the good people here, put a little time and effort in up front, and you will soon be producing videos you are proud of, instead of something that looks more like it should be shown on a bigfoot or UFO website (you know the stuff - blurry, over compressed and and completely unwatchable)Read my blog here.
If you convert your VOB/MPEG-2 files to DivX, you'll get great compression and be able to easily self publish them on your website with the DivX Plus Web Player. MPEG isn't really that common of an Internet format, and if you use DivX, you get the convinience of being able to publish with the free DivX Plus Web Player as well as having your content in a format that can still play on a lot of devices (e.g. Playstation 3, certified TVs, phones, and blu-ray players).
There's a free web developers guide here:
http://developer.divx.com/docs/DivX_Web_Player/
And a code generator to help you embed your posted DivX files here:
http://labs.divx.com/WebPlayerCodeGenerator
Also, as of the latest release, the DivX Plus Web Player added DivX Plus HD support, meaning it can play MKV/H.264/AAC, should you decide to convert your MPEG videos to MKV, which is a very popular Internet format for HD.
Here's more info about the DivX Plus Web Player, too:
http://www.divx.com/en/software/divx/web-player
URGENT - How to convert VOB to Beta SP for Broadcast TV
By arlfolio in forum Video ConversionReplies: 0Last Post: 1st Jun 2009, 16:47 -
Replacing VOB files : Need urgent help with chapter menus !
By Ash512 in forum MacReplies: 1Last Post: 12th Mar 2009, 05:26 -
Convert VOB taken with a camcorder to an mpeg
By hygieneboy in forum Video ConversionReplies: 8Last Post: 3rd Mar 2009, 23:55 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 05:06 -
Convert screensaver files to some form of movie?
By michaelmcgennan in forum MacReplies: 3Last Post: 27th May 2007, 09:41
