Is it possible to store photos on a CD or DVD for use on a computer, and also be able to view them on a DVD player (using the same disc)?
Thanks in advance for any tips. I've looked everywhere for an answer!
Mellie
Results 1 to 10 of 10
Welcome Mellie
Yes its possible ... the only requirements is to check your dvd players file type support
Some dvd player manuals will specify folder / file organization, naming restrictions and limits ... stick with those as your guideline and you shouldnt have any issues -
We don't have a manual for the DVD player.
We've tried putting in a data DVD and a CD and it won't play. When we put photos and/or video on either, using a DVD (or slideshow) maker, the player will play it but the files are unusable.
Thanks,
Mellie -
Files are unusable? How? On what machine? More info needed.
Almost any DVD player will play a series of JPG files stored on a standard data disk. Some prefer DVD, or CD, or will handle both.
Video, and slideshows, are a different animal, authoring concerns come into play. Simply burning a disk full of standard JPG files almost always works.
Google the make and model of the player, 99% you can find the manual online. -
The photos in a slideshow are unable to be accessed, when I put the disc into the CD-rom on the computer.
I'd like to do what you explained in your second sentence. I tried inserting a data CD into the DVD player and it said "Disc error", the same thing that happened when a data DVD was inserted.
I'm looking for a manual online.
Thanks,
Mellie -
I found the manual. It looks like a photo DVD should work. I've been using a DVD-R.:/
I'll try it out when we get a DVD and let you know what happens.
Thanks,
Mellie -
DVD+R should work. I'm almost 100% sure.
I love to make video's of family photo's and video's so that I can keep them on my computer and on a disc for simpler view.
I would suggest downloading a free program that specializes in making these kinds of video's. Most computer's will come with a free trial or something but if you find a good program than you can tweak your slide show (add music, affects, colors, wording) than you will make tons of them and enjoy doing so.
Good luck and enjoy. -
Thank you for your help.
I do have a program for making slideshows, and like to do that. But, once you make a slideshow with the photos, that disc will play on a dvd player but is not a data disc anymore. The photos are unusable on a computer for any other purpose than to watch as a movie.
What I'm trying to do is put a bunch of photos on a disc for storage and also for viewing on TV. -
Originally Posted by Mellie
It's possible that your DVD player will not create a slideshow from a set of JPG files. In that case, most slideshow programs have an option to put a copy of the original files on the disk. Would reduce storage space, but unless you had a disk compatibility problem, that may be the best option.
Storing & Playing Video from hard drive
By bertmartin in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Dec 2010, 11:24 -
Storing avchd video on flashcard (SDHC)
By haschopapa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Dec 2009, 09:52 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 12:31 -
Viewing Photos On A DVD On TV
By joedough in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2009, 10:37 -
Converting Composite Video & Storing w/o Computer
By Pierbridge in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2007, 08:43
