stream.yuv from 480p webcam, generated by VLC (version above 1.0), transcodes fine when yuv4mpeg header option is included in the stream dump. But cpu limits make the result choppy and with freezes lasting several seconds.
With yuv4mpeg turned off (the VLC default for yuv output), conversion to avi with ffmpeg is beautiful, except the screen slips left to right, like a tv with bad horizontal hold, along with orthogonal regions of color that look like misplaced leftovers from one of the yuv's.
I know the stream from the webcam is in yuyv, however the linux manpage gives no different instructions for yuyv as opposed to planar yuv (besides which, it worked with the headers).
conversion was, on command line:
ffmpeg -sameq -s 640x480 -i stream.yuv test1.avi
2-pass conversion went fine, assuming I did it right, but produced same result:
if links are allowed in this forum, here's a sample of test2.avi:Code:dan@frankenstein:~$ ffmpeg -sameq -s 640x480 -i stream.yuv -pass 1 test2.avi FFmpeg version SVN-r19352-4:0.5+svn20090706-2ubuntu2, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --extra-version=4:0.5+svn20090706-2ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --extra-cflags=-I/build/buildd/ffmpeg-0.5+svn20090706/debian/include --enable-shared --disable-static libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.31. 0 / 52.31. 0 libavdevice 52. 1. 0 / 52. 1. 0 libavfilter 0. 4. 0 / 0. 4. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Oct 13 2009 22:15:16, gcc: 4.4.1 Input #0, rawvideo, from 'stream.yuv': Duration: N/A, start: 0.000000, bitrate: N/A Stream #0.0: Video: rawvideo, yuv420p, 640x480, 25 tbr, 25 tbn, 25 tbc Output #0, avi, to 'test2.avi': Stream #0.0: Video: mpeg4, yuv420p, 640x480, q=2-31, pass 1, 200 kb/s, 90k tbn, 25 tbc Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding frame=12555 fps= 13 q=0.0 Lsize= 501067kB time=502.20 bitrate=8173.5kbits/s video:500761kB audio:0kB global headers:0kB muxing overhead 0.061099% dan@frankenstein:~$ ffmpeg -sameq -s 640x480 -i stream.yuv -b 9000k -pass 2 test2.avi FFmpeg version SVN-r19352-4:0.5+svn20090706-2ubuntu2, Copyright (c) 2000-2009 Fabrice Bellard, et al. configuration: --extra-version=4:0.5+svn20090706-2ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --extra-cflags=-I/build/buildd/ffmpeg-0.5+svn20090706/debian/include --enable-shared --disable-static libavutil 49.15. 0 / 49.15. 0 libavcodec 52.20. 0 / 52.20. 0 libavformat 52.31. 0 / 52.31. 0 libavdevice 52. 1. 0 / 52. 1. 0 libavfilter 0. 4. 0 / 0. 4. 0 libswscale 0. 7. 1 / 0. 7. 1 libpostproc 51. 2. 0 / 51. 2. 0 built on Oct 13 2009 22:15:16, gcc: 4.4.1 Input #0, rawvideo, from 'stream.yuv': Duration: N/A, start: 0.000000, bitrate: N/A Stream #0.0: Video: rawvideo, yuv420p, 640x480, 25 tbr, 25 tbn, 25 tbc File 'test2.avi' already exists. Overwrite ? [y/N] y Output #0, avi, to 'test2.avi': Stream #0.0: Video: mpeg4, yuv420p, 640x480, q=2-31, pass 2, 9000 kb/s, 90k tbn, 25 tbc Stream mapping: Stream #0.0 -> #0.0 [mpeg4 @ 0x8514b30][lavc rc] Using all of requested bitrate is not necessary for this video with these parameters. Press [q] to stop encoding frame=12555 fps= 13 q=0.0 Lsize= 501067kB time=502.20 bitrate=8173.5kbits/s video:500761kB audio:0kB global headers:0kB muxing overhead 0.061099%
http://www.youtube.com/watch?v=LUVpDsq-QJU
Any parameters that can fix this? Using the headers is not gonna be an option. So far mencoder has produced the same exact result.
Hi-
I'm having a similar problem with the horizontal scroll. Did you ever figure out how to fix this?
Thanks,
Michael
Flip horizontally Avidemux?
By Boxiom in forum Newbie / General discussionsReplies: 10Last Post: 14th Feb 2012, 10:20 -
How to move videos horizontally
By mithiran in forum EditingReplies: 3Last Post: 22nd Nov 2011, 23:51 -
Easiest way to flip video horizontally
By bseos in forum EditingReplies: 3Last Post: 18th Oct 2011, 14:27 -
Converting 16:9 DV-AVI to Divx/XVid, its always horizontally squashed...
By mjvgiese in forum Video ConversionReplies: 2Last Post: 20th Jan 2010, 22:18 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44
