I recently burned a copy of a movie i have to a dvd and when i try to play it on my tv it cuts off a large amount from the sides but when i play it on my computer ( through the dvd) it comes out perfectly fine. I played with all the zoom functions on my tv and can't get it to fit right. Any ideas?
Closed Thread
Overscan - look it up in the glossary, then do a search for the term to get solutions.
Read my blog here.
use media info on the source file put it in text mode and copy and paste the results here. do the same to the video_ts folder of the dvd.
also what did you use to make the dvd?--
It shouldn't, but there have been a few TVs shown here that cut a lot of screen off. There have also been people who swear that that lots of the screen has been cut off when in reality it has only been the normal few %.
It could also be a DVD player that has been set to P&S widescreen footage, or a piss poor conversion that cut the edges off.
Given that the DVD plays to full width on the computer, it is unlikely the latter.Read my blog here.
i used dvd santa to make the dvd.. no problems before and here is the info
SOURCE FILE:
General
Complete name : C:\Users\Owner\Downloads\Drag.Me.To.Hell.2009.DvDR ip-FxM\Drag.Me.To.Hell.2009.DvDRip-FxM.avi
Format : AVI
File size : 701 MiB
Duration : 1h 38mn
Overall bit rate : 992 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 38mn
Bit rate : 854 Kbps
Width : 664 pixels
Height : 282 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.190
Stream size : 604 MiB (86%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 90.5 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 504 ms
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 2 -lowpass 17 -b 128
General
Complete name : C:\Users\Owner\Downloads\Drag.Me.To.Hell.2009.DvDR ip-FxM\drag.me.to.hell.fxm.nfo
File size : 3.28 KiB
VIDEO_TS:
General
Complete name : C:\TempDVD\VIDEO_TS\VIDEO_TS.BUP
Format : DVD Video
Format profile : Menu
File size : 106 KiB
Video
Format : MPEG Video
Bit rate mode : Variable
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
General
Complete name : C:\TempDVD\VIDEO_TS\VIDEO_TS.IFO
Format : DVD Video
File size : 106 KiB
Video
Format : MPEG Video
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_0.BUP
Format : DVD Video
Format profile : Program
File size : 80.0 KiB
Video
Format : MPEG Video
Format version : Version 2
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Standard : NTSC
Audio
Format : MPEG Audio
Format profile : Version 1
Menu
List (Audio) : 0
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_0.IFO
Format : DVD Video
Video
Format : MPEG Video
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Audio
Format : MPEG Audio
Menu
List (Audio) : 0
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 021 MiB
Duration : 27mn 5s
Overall bit rate : 5 270 Kbps
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : No
Duration : 27mn 5s
Bit rate : 4 677 Kbps
Nominal bit rate : 8 200 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.452
Stream size : 906 MiB (89%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 27mn 4s
Bit rate : 384 Kbps
Video delay : -33ms
Stream size : 74.4 MiB (7%)
Menu
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_2.VOB
Format : MPEG-PS
Duration : 29mn 4s
Overall bit rate : 4 910 Kbps
Video
Format : MPEG Video
Duration : 29mn 4s
Bit rate : 4 332 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.418
Stream size : 901 MiB (88%)
Audio
Format : MPEG Audio
Duration : 29mn 4s
Bit rate : 384 Kbps
Video delay : -140ms
Stream size : 79.9 MiB (8%)
Menu
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_3.VOB
Format : MPEG-PS
Duration : 29mn 0s
Overall bit rate : 4 921 Kbps
Video
Format : MPEG Video
Duration : 29mn 0s
Bit rate : 4 342 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.419
Audio
Format : MPEG Audio
Duration : 29mn 0s
Bit rate : 384 Kbps
Video delay : -131ms
Stream size : 79.7 MiB (8%)
Menu
General
Complete name : C:\TempDVD\VIDEO_TS\VTS_01_4.VOB
Format : MPEG-PS
File size : 622 MiB
Duration : 13mn 40s
Overall bit rate : 6 365 Kbps
Video
Format : MPEG Video
Duration : 13mn 40s
Bit rate : 5 728 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.553
Stream size : 560 MiB (90%)
Audio
Format : MPEG Audio
Duration : 13mn 40s
Bit rate : 384 Kbps
Video delay : -127ms
Stream size : 37.6 MiB (6%)
Menu
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
3d movie has spilt screen I want it full screen please help.
By stadelbauer in forum Newbie / General discussionsReplies: 9Last Post: 18th Dec 2013, 17:46 -
laptop screen size too big
By angryassdrummer in forum ComputerReplies: 7Last Post: 14th Feb 2011, 22:20 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20 -
Using My Big Screen For Pc Monitor
By Robspace1 in forum DVB / IPTVReplies: 11Last Post: 13th Jun 2007, 12:55
