    Jan 2010
    Canada
    Hi, I am new here
    My firs question is how can I resize to a lower resolution (half) a .wmv video with the same audio and video bitrate and specs ?
    I have use windows media encoder, but I cant figure how to do a SIMPLE resize ?
    Any help very appreciated.
    Jan 2010
    Canada
    Thank,
    But how can I keep the same compression, I just want to change the size ?
    Use same bitrate and you will get same compression/file size. But you must reconvert/recode.
    Jan 2010
    Canada
    Ok, thank
    Does some software offert to keep the same bitrate or I have to manualy select it ?
