I successfully moved clips I took with a FLIP Ultra HD into my Vegas Movie Studio Platinum 9, but I find they play in a herky jerky fashion, more like a series of fast movie pics rather than a smooth video. Would upgrading to either Vegas Movie Studio Platinum Pro Pac or to Vegas Pro 9 solve the problem? Thanks, Frank
Thank you. I did not realize that I had to change the frame rate, and don't know how. I ran a segment through Media Info and got the following: MPEG4 (Sony PSP) 30.7 MiB, 28s 266ms. This is the first attempt I've made but I plan burn what I shoot onto a DVD.Originally Posted by MOVIEGEEK
Just burn a DVD because what looks jerky on your PC may look fine on your tv.
If after playing on tv that it still looks jerky then you should try another encoder(look in Tools).
Here's another tip: the video from your camcorder is progressive(frame based) so I would use that instead of interlaced(field based).
Vegas Movie Studio Platinum 9 startup...
By Anonymous4374945 in forum EditingReplies: 5Last Post: 8th Jul 2011, 14:28 -
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 21:28 -
Vegas Movie Studio Platinum 10.
By EagleW in forum EditingReplies: 0Last Post: 15th Jul 2010, 21:03 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
