I've just downloaded RipBot264 v1.15 and I'm not amused. As usual it comes with an .ini file where you can alter program settings. BUT: The option to check for installed components has been removed. So I need to install Haali to get it to run. The version I used before offered that option to turn off the check.
Is there any workaround? Or will I have to install Haali to get this actually great program to work?
what's wrong with haali media splitter? It adds support for .ts .mp4 and .mkv files. also it is required by eac3to!
Ripbot264 audio options
By jamesj84 in forum Newbie / General discussionsReplies: 8Last Post: 8th Feb 2012, 19:22 -
Ripbot264 1.17
By rapunzel in forum Newbie / General discussionsReplies: 7Last Post: 6th Jan 2012, 18:05 -
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 07:00 -
how does Ripbot264 think ... ?
By zero7404 in forum Blu-ray RippingReplies: 42Last Post: 3rd Oct 2011, 21:23 -
Can't decompress Ripbot264
By ranchhand in forum DVD RippingReplies: 3Last Post: 10th Apr 2011, 23:02
