Audio is great in Viewer but when moved (by any Means) to Timeline all I get is a red line and beeps.![]()
Only Single-Payer will reform healthcare.
The red line means the audio format isn't supported. Change it to something FCP3 supports.Originally Posted by Davideo2Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Keeping the Q short, I didn't mention that none of the render options under Sequence did anything but if I left the pgm running long enough(over 45 min) it does an auto render on its own, and then the audio is fine.... Normal?.....Weird
Only Single-Payer will reform healthcare. -
Where is your video and audio coming from, is it from a camcorder that is being captured by Final Cut Express. I have had a similar problem with converting a DVD to DV format with ffmpegX. Video is OK when imported but the audio must rendered to use it and it takes 90 seconds for 1 minute of audio.
Clarification with Final Cut Express, particulary the Audio Pan and AspectR
By TagoFilm in forum EditingReplies: 7Last Post: 8th Aug 2015, 14:39 -
Final Cut Express audio sync
By EagleAye in forum MacReplies: 4Last Post: 24th Apr 2012, 18:39 -
Need to render audio in Final Cut Express?
By Bill_Friedman in forum ffmpegX general discussionReplies: 1Last Post: 17th Feb 2011, 23:50 -
Final Cut Express- splitting audio from video
By ker-plop in forum MacReplies: 10Last Post: 4th Jul 2008, 15:40 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
