I was using WMM to edit videos and it worked fine, but when I got new computer, I was having following issues...
-Audio (song) length in timeline differs from the original, sometimes shorter, sometimes longer (even doubled), when I just play the song it works, but itīs imposible for me to sync the video with audio, when timeline isnīt accurate.
-I tried Cyberlink Powerdirector in hope that itīll work. Audio length matches, but when I pick moment in timeline (Without video, just song in Audio trail) itīs off by 5-30 seconds !!
Since Iīm having similar problem with both, Iīm guessing it has to do something with codecs I use.
PS: Iīve already tried compatibility and filter based solutions.
Help would be appreciated.
check your source audio files. if they are vbr or an odd format, then try converting to wav before using them for video work.
Iīve already tried that, In prewiev mode the length matches, but in timeline itīs 40seconds shorter than original ...
But thanks anyway. -
Iīve downloaded new codecs (No Divx) and .wav file works normally for Powerdirector (Mp3 etc. still same issue)
I can at least start working now, but still I would appreciate solutions.
Windows Movie Maker 6 - Problems with playing timeline
By leegutcher in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2013, 13:16 -
How to Separate 5.1 Audio Channels? Experiencing Extreme Frustration
By Nicolai Philippe in forum AudioReplies: 7Last Post: 15th Aug 2010, 17:35 -
Audio glitching on FCP timeline
By Fraser in forum MacReplies: 2Last Post: 12th Jul 2010, 09:22 -
timeline problems - IFO mode only (VOBSET works)
By charliem in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Aug 2009, 05:32 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 17:34
