Hi all, i have been using this program for movies and its great for converting DTS to AC3 but i had windows XP now that i have windows7 it wont load, just a quick flash and thats it.
any suggestions.
I have not used Windows 7, but one of my co-workers has tested it (it's going to be rolled out in 2010 company wide, but most users don't have it yet and I use XP at home). He tells me that Windows 7 has a compatibility option where you can specify that specific programs run in a previous version Windows. Perhaps if you set this to XP for your program it will run OK. I think it's definitely worth trying. He told me that he felt that the compatibility option was significantly improved in Windows 7 over the same thing in previous versions of Windows.
mp4box can't convert dts to ac3. I guess the quick flash you see is the command line version of mp4box. Maybe you are thinking of something else? For mkv dts to ac3 use popcorn mkv audio converter.
ok sorry your write, i saved the wrong program bugger.
ill try to find it again its the best program ive used for converting dts to ace so easy.
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 15:26 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / IPTVReplies: 7Last Post: 25th Feb 2013, 18:26 -
Repair corrupted mp4 (no moov box error)
By kkelis_ in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2011, 02:44 -
Playing smooth streaming fragmented mp4 without trex box
By adammw in forum Software PlayingReplies: 0Last Post: 29th Jul 2010, 02:01 -
Shadow box after converting to Mpeg2/MP4/FLV
By LouieLand in forum Video ConversionReplies: 6Last Post: 1st Feb 2010, 13:11
thanks anyway.
