i bought a Sony HDR-CX100 High Definition Handycam Camcorder recently and i just recorded about 1min to see how it works, when i transfered the file to my computer, and tried playing the file with VLC media player, it isn't playing smoothly, the video (is stuttering) i also tried playing it on nero, win dvd pro, cyberlink dvd 9 and it's still doing the same thing, can someone help me as to what i'm doing wrong or if it's software or hardware problems?
thanks
chris
If your posted computer details are correct, your PC is marginal for HD playback. But try MPC-HC. It's optimized for HD playback. If you still get poor playback, I would upgrade your video card as the most cost effective change. If that's not enough, then a faster CPU may be needed. A quad core CPU running at about 2.5Ghz or more would definitely do the job, along with a good video card. You would most definitely need a faster CPU if you plan to edit or re-encode HD video frequently. It uses a lot of computer power and hard drive space.
Check your CPU usage during HD playback with Task Manager and you may see the problem right there if the usage is above 50%.
And welcome to our forums.
i just checked the CPU usage and it went to 100%, so i guess the problem is my hardware. Thank you for your reply.
mkv to m2ts playing on my blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2010, 17:24 -
MPC not playing m2ts and ts files
By krohm in forum Software PlayingReplies: 36Last Post: 25th Aug 2009, 08:43 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 10:47 -
Planet Earth each m2ts file playing same episode
By mwsolomon in forum Blu-ray RippingReplies: 0Last Post: 18th Feb 2009, 00:16 -
Playing .m2ts from AnyDVD-HD ripped BD movie
By hartski in forum Blu-ray RippingReplies: 2Last Post: 24th Nov 2008, 05:03
