Hi
I have just acquired an Archos AV500 and want to convert some DVDs for use on the Archos .I have used handbrake to convert them to MP4s but they will not play.
Does anyone know what formats the machine will play and the best freebie software to convert them
http://www.archos.com/support/download/manuals/EN_AV500_v25.pdf
According to the manual listed above, "The AV 500 plays .AVI files that are encoded with in MPEG-4 format. It can play such video files at a maximum size of 720 x 576 pixels (25 frames/second). It can also play .WMV files (WMV9 SP) up to a maximum size of 352 x 288**. The AV 500 will not directly play files of type .mov, .mpg, or .mpeg."
You might want to try "Avidemux 2.5" (www.avidemux.org). If I am not mistaken, it can convert to various formats and, best of all, it is free and simple to use. Good luck.erryutkill
Archos 605 Video Encoding
By DJboutit in forum Video ConversionReplies: 4Last Post: 27th Dec 2009, 14:38 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
archos 7 VOB files and subtitles
By stevencg in forum Video ConversionReplies: 3Last Post: 31st Jan 2009, 18:17 -
Archos AV700 and 'Copy protected Video files'
By florent_g in forum Video ConversionReplies: 11Last Post: 8th Nov 2008, 10:14 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 05:49
