HI guys, i am new to this and was wondering how i should render in Sony Vegas 9 for dvd. If i import an mpeg2 file to work on then render it with variable bit rate, it compresses the file. if i set it to constant bit rate it fine. Is it ok to leave as constant bit rate?
sure. you may have to use a slightly higher bit rate with cbr to make the action scenes look ok, but that's about it.
hehe, it just depends on how long your video is and how high the bitrate of your audio is. if you are using pcm or multiple audio tracks the total could go too high. filesize = bitrate x time. if you are making a dvd use a bitrate calculator to determine the approximate bitrate.
Need help - rendering in Vegas
By Rairun in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2011, 19:51 -
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Basic Rendering Settings for DVD using Sony Vegas Pro 8
By JerryRecords in forum EditingReplies: 1Last Post: 2nd Aug 2009, 14:13 -
Vegas 8/8.1/9 crashes when rendering on I7 (HD)
By rethox in forum EditingReplies: 0Last Post: 18th May 2009, 06:41 -
Rendering with Vegas 8
By seven1970 in forum EditingReplies: 27Last Post: 23rd Feb 2009, 12:44
