I was able to extract a vob from a damaged dvd, however the vob is 3 gigs. What freeware can I use to split the vob into standard 1023MB sections?
If you want to turn it into a DVD (which is implied by wanting it back to standard VOB size chunks) then hech54 has nailed it. Because not only do you need to get the VOBs to a compliant size, but you also need the other files you are missing. Authoring will create these missing files for you.
Are you sure that the VOB you have is complete ?Read my blog here.
Not free but if it's a one-off job use the free or the trial version of VSO ConvertXtoDVD - it will reauthor from a vob file/sOriginally Posted by pinetopSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
u could create an .ifo file with ifo edit then run it thru vobblanker..it would separate the large vob into 1 gb chunx
ConvertX would re-encode it -- bad idea.
Re-authoring with authoring software. Try TMPGEnc Authoring WorksWant my help? Ask here! (not via PM!)
IIRC, DVDstyler will author w/o re-encoding, if mpeg2 compliant of course..Or demux with DgIndex and re-author with say, DVDAuthorGui or similar..
" Who needs Google, my wife knows everything" -
Thanks for the replies.
I did try to author with TDA 1.6 and ulead before posting here. I also used ifoedit and vobblanker before posting. None worked for my vob.
Heres what did:
Shrink 2.3 split my 3gig vob up but stopped at 99% complete, it did everything but the ifo and bup files. No encoding it was done in 2 minutes. I then used ifoedit for the ifo/bup files. And finally authored with tda 1.6.
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 02:09 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 19:41 -
DVD to one big VOB using ImgBurn
By Dave81 in forum DVD RippingReplies: 10Last Post: 25th May 2007, 08:42 -
DVD to one big VOB ?
By rindless in forum DVD RippingReplies: 5Last Post: 19th May 2007, 04:42
