    Jun 2005
    The Netherlands
    Hello,
    I got this video from the official Avatar Movie website. The problem is that the video does not play smoothly. I imported the video in AVSEdit and applied the SeparateFields() command. Then I exported it using x264 in VirtualDub (see the sample in the attachment). When I watch the video frame by frame, some frames are blended and some frames are kind of double. What is the proper way to IVTC (I don't know whether this is the right term or not) this using avisynth?
    Sample: sample2.avi
    The final destination for the video is supposed to be DVD.
    Oct 2005
    666th portal
    if the sample is part of the original then it's not interlaced. if it's not the source then a sample of the original is needed.
    Jun 2005
    The Netherlands
    I imported the video in AVSEdit and saved it with VirtualDub, so obvious it's not the original.
    Link to the original file: Here
  4. Your second link doesn't work. Not for me, anyway.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    sorry i should have read the first post more carefully. like manono says the link to the original doesn't work, but if it's really a youtube video then your source was progressive also and the bad encoding is already in it and can't be fixed.
    Jun 2005
    The Netherlands
    Now, the link doesn't work for me neither, I think it was in my cache temporarily.
    I got the original video from YouTube indeed (here). So I guess repairing it using AviSynth is no option.
    Thanks for your help.
  7. You can pull out the duplicate frames (and I would when reencoding), but as it's been deinterlaced already you can't unblend it.
    Jun 2005
    The Netherlands
    Yes, using tdecimate(1,1,5) on the original does make the video play much smoother. Thanks.
