Sorry, I didnīt know where to post this and the searche engine was offline, so I couldnīt check if anyone had already asked about this. Here it goes:
I would like to prevent my VCDs (burned with Nero 5 using a 3rd party player) from being copied by my clients. I would like then to protect the player (a .exe file) and the .dat (the video) itself. I tried the CD protector (using the audio dummy tracks method) , but it required a time consuming process and CD-RW media. Furthermore, it protected the CD-CD copy, but not the copy of the files from Windows Explorer, so it didnīt work for me. Anybody can help me on that one?
Thanks a lot.
Andre Senra
ROFLOL
Nothing will prevent the vcd from being copied that won't interfere with its playability. -
You are wasting your time trying to make your CD-R's copy proof.
Andre,
There's no REAL way of 'Copy Protection' when your when your giving Cleints 'home-brewed' stuff ...
I'm sorta having the same problem, I film most of my 4x4 trips and convert them to vcd (by press..... (explain ?? I send my film to a hardware video press to have them done in quantity))...
Alls you can really do is copyright your material......that's about it
.................................................. ...........Bizzaro
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 06:42 -
protect after/before authoring
By pcb in forum Newbie / General discussionsReplies: 8Last Post: 8th Mar 2008, 00:16 -
How do I copy protect a dvd?
By goheadtry in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2007, 17:22 -
password protect movies
By hackerzlab in forum Newbie / General discussionsReplies: 9Last Post: 31st Oct 2007, 10:47 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
