I just bought a video media player that can only support max RMVB resolution up to 1024x576.
How can I change the RMVB video file with Full HD 1280x720 to HD?
@Willie
Current Events & Trade Fairs Calendar
You would have to re-encode them and set a smaller video framesize in the encoder settings. You will have quality losses, unfortunately.
I'm not sure why someone would create a 1280x720 HD RMVB file though.
But welcome to our forums.
Many converters will allow you to use or edit an AviSynth script the program reads during the conversion. There are a bunch of resize filters out there. Some look better if you are resizing larger, but some can produce output with jaggies if you are resizing smaller. A good idea is to slice off a small piece of video and do a few conversions with various resize filters and look at the output. Here's one site with a bunch of filters:
http://avisynth.org/warpenterprises/
Or the encoder program may have several to choose. Check the help. Sometimes it will advise which resizer to use depending on if you are upsizing or downsizing.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
What's the fastest way to change video resolution?
By Phantoms Cry in forum Video ConversionReplies: 2Last Post: 16th Jan 2012, 16:51 -
change screen size of rmvb video
By vcd_user in forum Newbie / General discussionsReplies: 0Last Post: 28th Jan 2011, 11:47 -
Change video resolution
By Browneyd in forum EditingReplies: 5Last Post: 11th Jan 2011, 11:34 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 18:33 -
How to change video resolution exactly in Virtual Dub Mod 16:9 to 4:3
By afcoff in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 12:49
