I have a new JVC deck in my Jeep that can play MPEG1 and 2 files through the USB port connected to a hard drive, the trick is the HDD needs to be FAT32 formated which limits my file size to less then 4gig. is ther a way I can "shrink" a MPEG2 files to less then 4G or create a MPEG1 (which I am assumeing will be smaller) from my AVI files?
Currently I am converting AVI to DVD using DVD Flick then using VOB2MPEG to create MPEG2 which puts all my files around 4.3g
	File size = bitrate * running time
 Use a low enough bitrate to fit the video into 4 GB. Use a bitrate calculator to determine what bitrate to use.
	Grammar Nazi mode on.
 The correct expression is "less than". It is not "less then".
 Grammar Nazi mode off.
	It appears that the software you are using is 'shrinking' your movie to fit on a single-sided (DVD5) disk.
 I would echo what was previous said that Tmpgenc is a good option to convert.
 If you do want to create mpeg-1 files then VCD quality will give you under 700 meg for an hour of video.
	As johns0 said, use Rejig, and set compression to 90%, or set the size to just under 4 GB.Originally Posted by Lisn2me
 Possibly there is a way to tune DVD Flick to make smaller files, but I've never used it.
 Maybe you could add another file, 10% of the size of the "real" one and do them together, then discard the second part's VOBs?
 There are more elegant ways to make MPEGs exactly the size you want if you want to use other apps.
  Best way to convert DV file to something that have smaller file sizeBy Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 07:14
  How to convert an MPEG file to DV-AVI Type 2 using MPEG StreamclipBy MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30
  Converting MPEG into a smaller file size?By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 23:36
  Can I make a AVI file smaller?By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04
  Convert Digital Camera avi's to smaller sizeBy nook in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2008, 07:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
