Results 1 to 9 of 9
    Apr 2008
    Europe
    Is there a tool to edit video in .iso files? Any recommendation?
    Just extract the video with winrar and then edit.
    This is what an ISO file is: http://www.digitalfaq.com/forum/showthread.php/why-iso-1849.html
    What do you mean by "edit" --- change the contents of the ISO, or edit something held inside of it (like video). If you want to edit video, then mount the ISO, extract the video, and edit.
    Is this a DVD image? if so, be sure to properly extract the DVD MPEG data, don't try to copy/rename VOB files. See a guide for this at http://www.digitalfaq.com/guides/video/edit-dvd-recorder.htm
    Oct 2005
    666th portal
    ultraiso can open, and you can change files in an iso then re-save it. maybe isobuster, never tried it though.
    Apr 2008
    Europe
    Great information, thank you all.
    @lordsmurf: by 'edit' I meant processing of a video embedded in an ISO, like cutting out ads.
    Then definitely mount the ISO, extract the video, edit it, then re-author and re-burn (or re-make ISO instead of burn).
  7. The .iso files cannot be edited at will, please read it if you do want to do that : https://www.iseepassword.com/iso-editor.html
  8. Hi everyone! Eyo's Avatar
    Nov 2018
    Australia
    Try Alcohol tool
  9. I have a voice,don't try so-called "free software" so easily,because I have wasted a lot of time on them.
