Hi Friends, I need to know if its possible to convert the footage I have on a mindv tape from NSTC to PAL,
I want to make another copy of the footage onto another Min-dv tape but have it in Pal formatt. And still keep it in DV-AVI formatt .Can this be achieved?
Thanks for all responds.
most likely. re-encode it from 29.97 to 25 fps PAL DVavi and print back to tape on a PAL cam. it's not going to be as smooth as the ntsc version because of the frame rate conversion but it should play.
Hi thanks for the comment aedipuss but I dont have a Pal cam. I thought I might be able to transfer it to my computer and than convert it to Pal on my computer than return it back to a tape.
It might work on a NTSC camcorder, firewire doesn't check for resolution or framerate.
I would do a one minute clip to see if it works. -
Hi forgot to ask ya aedipuss, what program would I use to do this (re-encode it from 29.97 to 25 fps PAL DVavi }
Hi MOVIEGEEK, I'll give it a try , but Iam using Corel Video Studio ProX2 shouldnt that do the trick as well?
I also change the video file from 29.97 to 25 and the frame size 720X480 to 720X576
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54 -
capture stuck when connecting my mindv
By forare in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2009, 07:39 -
Nstc to Pal
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 9th Jul 2008, 15:42 -
HD minDV to DVD
By Hazel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th Apr 2008, 09:42 -
Best 1080P Upconverting PAL/NSTC Region Free Player?
By miamiloco in forum DVD & Blu-ray PlayersReplies: 17Last Post: 29th Nov 2007, 09:37
