Hi Everyone,
My friend was filming (he really sucks) the whole scene is just too shaky.
I hope someone can help me with providing the best/better settings. I want to create a video where this scene is a part of.
I use Deshaker with VirtualDub. The guides on internet didn't help much.
But I've seen similair shaking with good results on Youtube. I think the problem is that this video is filmed while walking and the guide's are more for just standing still and less shaking. I've experimented alot but there just are some crazy artifacts in the video
Great guides I've followed but didn't work
http://www.guthspot.se/video/deshaker.htm
http://www.sundancemediagroup.com/articles/deshaker_guide.htm
Here are the samples
Original (whole scene is longer but similair bad shooting)
http://www.megaupload.com/?d=WNK9M18G
Deshaked, in the end you see a artifact
http://www.megaupload.com/?d=LS6VNLAI
Results 1 to 10 of 10
The flag once raised will never fall!
That's a pretty low quality sample. It already has letterboxing, and has been processed. What other things were done to it?
What does the original footage look like? It might be better to upload an original sample
Clarify what artifact are you speaking of? Is it in the original footage as well? or only after using deshaker? -
If the video has black borders -- crop them away before attempting to deshake.
Got the video now...
Also, do not use blend deinterlace that will totally confuse the deshaker. Use something smarter like Yadif. -
The video is bad shooted and shaky. After the deshaker at the end of the sample there is a artifact, hard to explain, I will upload the original MP4 and a sample of what I get after deshaker.Originally Posted by poisondeathray
But VirtualDub can't handle MP4, I hope you have the Directshow plugins
The flag once raised will never fall! -
http://www.megaupload.com/?d=LS6VNLAIThe flag once raised will never fall! -
The distortion at the end of your file is from deshaker trying to fill in the borders with data from other frames. It doesn't work perfectly. Instead of filling the borders crop away the black borders that creep in without it. Default deshaker settings, cropping 48 pixels of the left and right edges, 32 off the top and bottom:
http://www.megaupload.com/?d=GTOZ3O1J -
Thanks for your effortOriginally Posted by jagabo
That looks very promising, hope it won't affect the video much. I hope there will be not too much zooms in the whole video ( I can turn that off maybe). On the other side I can't stand that original shooting, it is just look too bad.
Tommorrow I will come with an answer after checking/testing the whole videoThe flag once raised will never fall! -
I've used the setting you said. It looks good.
Sometimes it isn't nessecairy to crop, so I cropped it manually.
Too much cropping/decropping can be annoying, so I did it at least as possible.
I've tried all edge compensations but the others wil have too much zoom.
This is the best I think. Thanks for the help.
Next time I will have to learn him shooting
Manual Shake Smoother from Unisoftlab can help you if you split the video into short fragments.
VirtualDub/Deshaker trouble
By she-ra in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2012, 09:12 -
Virtualdub with Deshaker problem
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2011, 10:39 -
Problem when using Deshaker Virtualdub filter
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 01:41 -
Need help with Virtualdub deshaker. Arrows all over the finalized video.
By cannondale1974 in forum EditingReplies: 4Last Post: 26th Aug 2010, 00:46 -
Problem w/artifacts using Thalen DeShaker in Virtualdub
By brassplyer in forum RestorationReplies: 113Last Post: 29th Apr 2010, 07:24
