Hi, newbie here. First, I apologise if this isn't the right place to ask but I found no solution searching other topics.
The video in one of my files is out of sync with the audio. The video is running at a slow 15 FPS in the original file, so the audio finishes a long time before the actual video. I changed the FPS to around 24 FPS which syncs the video and audio but only in the beginning of the video, when a lot further into the video it goes out of sync again...
I think the problem is that the video is slowed down, but not equally slow over the entire video. I can either sync the beginning of the video, which causes the later part to go out of sync (video too slow) or I can sync the later part, which causes the beginning to go out of sync (video too fast).
Also the original file is a DivX file, I already converted some copies to AVI, MPEG,... but they all have the same problem.
Is there any way I can fix this?
Not likely if the source is out of sync. There are ways to get the audio length to match the video length but the sound won't be in sync(ie lip sync).Is there any way I can fix this?
I thought so already, I'll see if I can salvage some parts by messing around with the FPS.
Thanks anyway for the quick response. -
My DV caps are also always slowly going out of syncOriginally Posted by MaxNH
This is what I use for DV captures (I only have experience on DV AVI captures)
Method 1 (after DV AVI capture)
- Open AVI in VirtualDUB
- Go to video - Framerate and then select adjust audio/video to framerate (in my case always 25.002)
- Save AVI (video: direct stream copy and audio: direct stream copy)
Maybe if you try the same method above with the 24fps video, change to 24.002 play around maybe it gets in sync.
I don't know wich format the video is, but you can use Directshow plugin https://forum.videohelp.com/topic348265.htmlThe flag once raised will never fall! -
Try 23.976 or 25 fps. If those don't work calculate how far off the audio and video are near the end of the video and adjust the frame rate accordingly.Originally Posted by MaxNH
For example, assume the video is 1 hour, 37 minutes, and 5 seconds long -- 5825 seconds. And suppose audio ends 7 seconds before the video when the frame rate is set to 24 fps. You need to increase the frame rate make it end 7 seconds faster. Ie, you need to make the video 5818 seconds long:
24 * 5825 / 5818 ~= 24.0288759
So you would set the video fps to 24.0288759.
The Video is fine - The Audio is noise
By andy jackson in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Feb 2012, 12:47 -
Audio/video fine on PC, out of sync on Mac
By scrolls in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2012, 21:48 -
Avi: fine, DVD: audio out of sync
By Sebastian2011 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2012, 13:32 -
Xbox 360 streaming -- audio of out sync (fine on computer)
By ycrazyy in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2010, 09:42 -
Problem fine tuning audio sync
By spark001uk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2009, 14:02
