  1. What is the longest video lenght you can use (short project) highest quality on when conveting to dvd?
    And will useing medium project setting give me major quality loss?
    Oct 2007
    Choose "Automatic" and the program will choose the best option based on your input.
  3. Member midders's Avatar
    Sep 2008
    If you're really worried about quality, then you'd be better off using a true encoder (HCEnc, QuEnc) etc. rather than ConvertX for your conversions.
